Want to get int the 6's 1/8= 10's 1/4
Old 05-08-2005, 07:28 PM
Tech Fanatic
yellowbird1232's Avatar
Default Want to get int the 6's 1/8= 10's 1/4
What would it take engine wise? It is a 02 WS6 m6 with sfc, lca,phb,torque arm,12 bolt,y-pipe,dr's. It runs 8.0 -8.4 in the 1/8 depending on the track. I have a street twin ready to go in.
Old 05-08-2005, 07:47 PM
beardWS6's Avatar
Car in Sig!
Old 05-08-2005, 08:41 PM
Full-Force's Avatar
yellow bird you are gonna need about 500+hp at the wheels to get in the 6's with a 6 speed and a chassis/suspension thats more setup for street
example, a member on here has pp stage 2 heads, tr228 cam, 4.30 gears, and a 100 shot to run 6.9's at 101mph
of course there are stock internal autos running 7.1's with only 325hp to the wheels but thats a car that is set up for drag racing
Old 05-08-2005, 08:54 PM
JZ'sTA's Avatar
I ran a 6.7 and mid 10 with a 224/226 cam, bolton's, converter and a 150 shot
Old 05-08-2005, 09:04 PM
Tally TransAm's Avatar
h/c+shot
i have the h/c part down, working on the shot
Old 05-08-2005, 09:05 PM
ChevPower's Avatar
I have tr224 on a 112lsa, 5.3 heads with 2.02/1.60 with bowl work only, ls6 intake, LT, off road Y flomaster cat back with a cut out, 3800 converter, 12 bolt 373, K-member, lower a-arms and subframe con. car went 6.88 at 103 with a 100 shot tnt
Old 05-08-2005, 10:06 PM
Moderator
JNorris's Avatar
Combo in the sig. But to be consistently in the 6s and 10s I would need more power.
John
Old 05-08-2005, 10:13 PM
ChevyGoldfinger's Avatar
Your sig doesn't say where you live. I haven't gotten there yet, but then our track in Vegas is 2200 ft. elev. and often the DA can be much higher than that.
Not everyone lives at or near sea level. My best so far, first time out, not even broken in yet with 91 octane pump gas and a very conservative tune, was 11.32 @ 120. This would equate to 10.7x or so in Florida? You have to take DA and track elevation into consideration. BTW, my car is heavier now than when it was stock. Full interior, A/C, power everything, original stereo, plus a steel rollbar and heavy assed 9" with heavy BMR parts.
Maybe some day I'll make a trailer queen out of it and get the race weight down under 3750 lbs.
Old 05-08-2005, 10:25 PM
Tech Fanatic
I live in northeast fl. Ferandina beach just north of jacksonville. I have an ls1 that I can build is why Iam asking.
Old 05-08-2005, 10:34 PM
Well, you're right close to sea level, so it won't take as much RWHP as it would here. Still depends on how much weight you're willing to strip out of the car. The key to this drag racing deal is, and always has been, HP to Weight ratio
Good luck to you.
