how's my clutch and flywheel look??
just pulled the tranny today... ready to start my rebuild. i'm a newbie so i have no idea what a used clutch should look like. car has 112,000 miles so i'm assuming the clutch isn't stock. to me it looks like **** and so does the flywheel. also, part of the slave cylinder is cracked as you can see in the pics, anyone know what could have caused this? thanks!
flywheel
clutch, pressure plate side
clutch, flywheel side
slave
flywheel
slave
that clutch has almost no ware for 112,000 miles, it looks exactly like ym z06 clutch sitting in my room adn mine is brand new
but then again you cant realy tell from a pic
Did you notice that your disc is broke? The steel hub inside the disc is sticking out you can see it on the picture below the flywheel. You never noticed this?? It should have been making some noise. Good thing you pulled the clutch.
I would change the Pressure Plate if it was mine. You are already there doing the clutch job, do you really want to do half of the job and possibly have problems down the road?
Good luck let us know how it turns out.
