Lean AFR for MPG
Old 05-11-2005, 10:34 AM
87GMC's Avatar
Default Lean AFR for MPG
Ok for some of us without lean cruise (us car, non-us have lean cruise) Would it hurt the motor to maybe set air-fuel ratio at 15.0 or so on a long trip. I just dont know if running a engine like that would have any benefit on mpg versus lean cruise on non us-cars. I understand lean cruise runs around 15.5 or but changine afr in parameter B3601would that help any or just hurt the engine more? I was even thinking of setting PE a little lower and raising PE afr a little higher. Im not going to be doing WOT runs or anything just strickly for highway trip. Let me know your opinions guys
Old 05-11-2005, 10:43 AM
HumpinSS's Avatar
YOu could do it but you qwould have to force the car into open loop
Old 05-11-2005, 10:53 AM
87GMC's Avatar
So setting the the commanded Afr to lets say 15.0 would force it into OL?
Old 05-11-2005, 11:08 AM
horist's Avatar
stock O2 sensors aren't very accurate past stoich so results may not be very accurate... if you forced the car into open loop, you could then use a wideband to lean accurately lean the car out tot he desired AFR
Old 05-11-2005, 12:23 PM
luv2spd's Avatar
I doubt that it would be worth all the trouble...
Old 05-11-2005, 01:30 PM
87GMC's Avatar
Just curious to save a few bucks but didnt want to hurt the engine. I know some other countries lean cruise is an option but didnt how it quite worked because like you said o2's are not accruate outside of sotich.
Old 05-11-2005, 08:43 PM
mr2guru's Avatar
Some of us are able to use the "lean cruise" functions of HPtuners..... IIRC 01+ vehicles. I am averaging 27-28mph on a H/C GTO with lean cruise enabled running about 16.5:1 Pretty neat feature. Those table were filled in from holden's lean cruise settings but I backed them off a bit since they run in the low 17:1 range!! Others are getting 30mpg....
Old 05-12-2005, 09:00 AM
87GMC's Avatar
I would love to use the lean cruise on my truck but I am unable to activate it. I can see it but even if were to try and kick it on the OS will not let us.
Old 05-12-2005, 10:54 AM
MrXerox's Avatar
There is a way to actually load your .bin file into a hex editor and change some values to enable the lean cruise. I have not been able to obtain these values from anyone yet because it seems they are scared they would be breaking the law. Posting the information is not illegal, preforming it is
Old 05-12-2005, 03:25 PM
87GMC's Avatar
Old 05-12-2005, 11:43 PM
TRex's Avatar
This is an interesting thought. I have an older truck that I think could benefit from a lean cruise mode, however I don't think the early pcm's had that feature (88 vintage TBI model).
So, I would have to lock it into open loop mode for lean cruise. Do any of you guys who have the lean cruise mode (aussies) know under what conditions the system goes into that mode ?
Old 05-13-2005, 03:32 PM
dr.mike's Avatar
The LM-1 has "Narrowband Emmulation" for just this purpose. You can replace your NB sensor with the LM-1 & its wideband sensor. Then, you can program the LM-1 to emmulate the narrowband signal at any AFR you want. 15.0, for example. This way, you can keep stock closed loop operation. It wll not affect open-loop/WOT operation.
With this setup, you can "lean out" for economy, just like we do with aircraft engines.
Quick Reply: Lean AFR for MPG
