What happended at 4400rpms
Old 05-13-2005, 06:54 PM
Silver 00 SS's Avatar
Default What happended at 4400rpms
http://66.223.119.133/camaro.pdf
Thanks Scott
Old 05-13-2005, 11:53 PM
cyipher's Avatar
We need to know more about your setup!
Old 05-14-2005, 12:35 AM
12 Second Truck Club
Magic Chicken's Avatar
almost looks like it shifted, but that's not it. also appears you went really lean right after the dip.
what are you running?
Old 05-14-2005, 01:26 AM
Wile_E's Avatar
Looks to me like you went lean and the PCM pulled some timing.
Like stated above, the more you tell us about your setup, the better chance we have at diagnosing your problem.
Old 05-14-2005, 08:49 AM
I have every bolt on minus the ls6 intake, NOS Nozzel 150 shot M6 with spec stage 3, Moser rear end 3.73 gears... Anything else?
Old 05-14-2005, 09:06 AM
cyipher's Avatar
Any programers installed, Fuel pump??
Old 05-14-2005, 09:48 AM
255 in tank pump
Old 05-16-2005, 02:00 PM
Need some help guys....
Scott
Old 05-16-2005, 06:16 PM
383LQ4SS's Avatar
very very strange. Looks like fuel cuts out at that rpm and slowly comes back in. be very careful until you get to the bottom of this. As a matter of fact...id put some 100 octane in the tank on all further runs. 100 octane will help alot if you do this hiccup again.
So this is a Noszle setup with the injector bungs? Two noids or four noids? Any window switches? Do you have a fuel pressure safety switch? As much info as you can give.
Old 05-16-2005, 11:10 PM
I got the window switch, it is the system that goes where the injectors go..... ill try 100 octane tomorrow night thanks for the hint!!!
Scott
Old 05-17-2005, 01:20 AM
383LQ4SS's Avatar
the 100 octane is just for safety while trying to figure this out. The 100 octane will not cure the problem.
watch your fuel pressure closely
