pressure plate to flywheel bolts???
Can I reuse the flywheel bolts from my auto flywheel? I'm about to put manual flywheel in, so just use threadlock, right?
Does anyone have exact part # from jegs or summit for the bolts that mate pressure plate to flywheel? Or can I use the same bolts that went to my tq converter?
Here you go here are the part #s for the bolts, these are ARP #s and I just got some myself. You will have to go to Summit. Jegs only had the flywheel bolts Summit had both.
FW ARP-330-2802
PP ARP-134-2201
FYI make sure you use some loc-tite and torque them to correct factory specs.
P.S pressure plate bolts are on back order as of a few days ago.
Chris
So am I dumb, or am I gonna have to buy special sockets for these bolts? I'd almost rather go with factory gm bolts, just so I don't have to buy all new special sockets.
Thanks for those #'s chris, sure will help many out.
