Lingenfelter 3.5" aluminum driveshafts $269.95
Old 05-26-2005, 02:26 PM
Closed ex-Sponsor Account
Ed Potter @ LPE's Avatar
Default Lingenfelter 3.5" aluminum driveshafts $269.95
We are expecting a big shipment of driveshafts from the manufacturer next week, and wanted to offer forum members a chance to pre-order.
Anybody that's finishing up a project, or needs a good strong driveshaft should really look into this. Full details can be seen here:
http://www.lingenfelter.com/store/ln0350s.html
Feel free to call or email me if I can answer any questions.
Ed
The following users liked this post:
TTOP350 (01-02-2021)
Old 05-26-2005, 05:11 PM
DrkPhx's Avatar
Ed
Pefect timing. I need one. Will it fit a Strange 12 bolt (I already have the 1350 u-joint)?
Old 05-27-2005, 01:28 AM
98cobrakillata's Avatar
How much rwhp can this drive shaft support?
Old 05-27-2005, 08:32 AM
The driveshafts come with the standard 1150 u-joints installed, or we can install a 1350/1150 hybrid before we ship for an additional 75.00. If you already have the right u-joint, we can remove the 1150, or send it as is and you can swap them.
Give me a call and I'll help you figure out which way to go.
These driveshafts are balanced to a much higher critical speed than any of the factory shafts, which gives them much more strength. We have used these on some very high RWHP cars 700+ without problems.
Feel freee to let me know if I can answer anything else for you,
Ed
Old 05-31-2005, 12:01 PM
DrkPhx's Avatar
Good service, I just ordered one. Thanks Ed.
Old 05-31-2005, 03:16 PM
Thank you Gino! We will get you that driveshaft ASAP!
Ed
Old 05-31-2005, 05:38 PM
nikon1999's Avatar
Default Question for you
I currently have a 10bolt and im putting a stall in the car, so thinking about doing the driveshaft at the same time. If i decide to go to a 12 bolt or 9" is the drive shaft still going to work?
Old 06-01-2005, 01:26 AM
I'm interested in driveshaft but I have an 8.8 rear.My stock driveshaft has ford jiont, that bolts on to my rear.Can I order a driveshaft with ford end or just buy your standard shaft, and transfer the one I have.
Old 06-01-2005, 09:12 AM
nikon99, yes, the shaft will still work later, you'll just need to install the hybrid joint, you can get it at any NAPA PN#448
98cobrakillata, I would suggest just buying the standard shaft, and installing your joint, since you already know which one you need(but I would get a new one of the same part # and install that) If you want, we can knock the stock one out before we send you the shaft.
Hope this helps,
Ed
Old 06-01-2005, 11:09 AM
Scoobie's Avatar
FWIW, i had one of these for my last car and the thing kicks ***. A lot less vibration after my gear swap was the main factor.
Old 06-02-2005, 05:35 AM
nikon1999's Avatar
does it work with the stock torque arm?
Old 06-02-2005, 08:11 AM
yep, stock or aftermarket torque arms both fit. When your installing it, and your susp. is at full droop, it's pretty close, but when you set the car back down, you'll have plenty of clearence
Thanks Scoobie
Old 06-02-2005, 09:10 PM
nikon1999's Avatar
well just ordered mine online! Cant wait
Old 06-03-2005, 04:23 PM
Boosted One's Avatar
Ed, Can you get a 3.5" drive shaft made to a specified lenght, for 1350 joints? I would like to put one in my Nova.
Thanks
Frank
Old 06-24-2005, 03:50 PM
Thanks
Frank
Hi Frank, I can definately get one made for you, to your specs, but the price will be different. Custom shafts usually run about 400.00 or so. If you're interested, call me and I can e-mail you a spec sheet to fill out, and we will order it to your specs.
Everybody else, we recieved confirmation today that we will have the f-body shafts on Monday!!!!!! If you have one on order, you should be getting a call from us on Monday to let you know it's on the way!
Thanks for everyone's patience,
Ed
Old 06-24-2005, 06:09 PM
DrkPhx's Avatar
Ed
Wohoo! My project will be finished soon. Thanks Ed!
Quick Reply: Lingenfelter 3.5" aluminum driveshafts $269.95
