2ohm midbass speakers for rearseat panel mount!!
http://www.cardomain.com/item/IDSCX62
has anyone tried these in there cam or bird yet, they are 2ohm like the factory monsoon system!!!
The depth is 3.125"
Here's some other specs from their website:
Voicecoil single 2 ohm
Nominal Impedance (IMP) 2 ohm
DC Resistance (Re) 1.8 ohm
Sensitivity (Spl) 91 dB
Recomended Power 150 watts
Frequency Response 45Hz - 4kHz in door
http://www.imagedynamicsusa.com/index.php#
Problem is, they are on backorder from the manufacturer with no set ETA on production. Well, at least that's what I was told by two different vendors, so I'm sure it's probably the case. If you can find them......
They wouldn't sound good because the Monsoon amp doesn't have enough power to push them. The recommended RMS power on those speakers is 150 watts. The Monsoon amp is no where close to making that much power. Those speakers are made to run off a real amp.
