What Pushrod Length??????please
Old 06-15-2005, 10:48 AM
NickcZ28's Avatar
Default What Pushrod Length??????please
I have bone stock heads milled 30 thous....????what length pushrod?????
PLEASE HELP!!!
Old 06-15-2005, 10:55 AM
ArKay99's Avatar
What is your cam base circle? What is your head gasket thickness? What was your stock head gasket thickness? What lifters? What rockers? What length are your valves if those have been changed? Have you checked your rocker tip wipe? You may need to shim. If all is totally stock (cam, lifters, and rockers), the stock pushrods are 7.380" so milling .030" should put you at 7.350". I would measure to make sure. A lot of bad stuff can happen if it's not set up properly.
Old 06-15-2005, 11:25 AM
crow2's Avatar
PLEASE HELP!!!
May be the safest bet to get a pushrod lenght checker to be on the safe side.
If you are using the stock camshaft and all you did was mill the head then you can normally figure 30 shorter on p/rods. I would probly start off with a 25 shorter p/rod.If you change headgaskets and valves ect..of course the thickness of the headgasket will need to be taken into consideration.then at that point you might even need a 50 shorter.good luck!
Old 06-15-2005, 12:27 PM
NickcZ28's Avatar
I have stock Gm headgaskets (new style) Stock Valves, bigger cam!!!The local shop said 7.40 Would be fine, Oh and the lifters are stock to0.....
Old 06-15-2005, 12:43 PM
2xLS1's Avatar
If your 98 heads still have the notch after milling, you cannot use the GM MLS gaskets. You will leak coolant.
Old 06-15-2005, 01:08 PM
NickcZ28's Avatar
SO WHICH GASKETS????
And are the 7.40's ok????
Old 06-15-2005, 01:13 PM
PREDATOR-Z's Avatar
98 graphite and yes on the 7.40
Old 06-15-2005, 01:33 PM
NickcZ28's Avatar
Whats the thickness on the 98 gaskets???Are they good to use??
Ohh and thanks for the info!!!!
Old 06-15-2005, 01:40 PM
PREDATOR-Z's Avatar
.054 compressed
Old 06-15-2005, 01:42 PM
NickcZ28's Avatar
why do they say to use the new style??
Old 06-15-2005, 01:50 PM
PREDATOR-Z's Avatar
Just look at the pic above. Then look at your heads, If that notch is still there, then 97-98 gaskets are to be used.
If that notch is gone and surface is flat, then it is OK to use the new style.
I forgot how deep that notch is but IMO .030 mill would still have it.
Old 06-15-2005, 02:10 PM
NickcZ28's Avatar
cool thanx!!
Old 06-16-2005, 09:01 AM
PREDATOR-Z's Avatar
I found out that some sponsors weld the notch when they prepare the heads. So that is why they say the new gaskets can be used.
Just inspect your heads for that notch if there or not.
Old 06-16-2005, 03:36 PM
Dan_the_C5_Man's Avatar
Old 06-17-2005, 12:42 AM
LS1 Swapper's Avatar
Originally Posted by Dan_the_C5_Man
Beyond weird, may as well contact a phone psychic
