90mm tb setup help
90mm tb setup help
im runing a big inch ls1 with a 90mm intake , 90mm tb , 85mm MAF now my question is should i run the 75mmlid wich i have now or go to the TSP 85mm lid, if i keep my 75mm lid whats hould i use for a bellow to go from the 85mm maf to the 75mm lid
Hi Guys
I used my 75mm lid with a clamp from Home depot - I think it was a 3.5 metal clamp (clamps attached to the unit). I removed the rubber piece and attached the 85mm MAF with the Lid. The inside diameter appeared to be the same as the MAF. I just butted them together and clamped.
Bill
Bill
LS1TECH Sponsor
Just installed the Fast 90, NW TB, 85MM Maf and lid. It all fit very well and the car started right up. It really needs a tune and I will get that at Speed Inc. on 7/15. It is running VERY rich right now. I went through almost 1/4 tank in about 35 miles.
You can hear the car breath with this setup. Sounds like a jet engine pulling air.
Will post tune results after the 15th.
I have NO experience modding an LS1 so I may be simplifying this too much. How can a 90mm TB and 90mm intake make much improvement if all the air has to go thru an 85mm MAF first? Won't this create too much of a bottleneck to realize much improvement?
Thx
Thx
LS1TECH Sponsor
The stock MAF and Lid are 75MM. the 85MM maf and lid are HUGE compared to stock stuff.
Yeah, all things being equal the MAF and Lid are still a little bit of a restriction. I don't think they will be much of an issue though.
