Need help... PLEASE..... Anyone
Old 07-03-2005, 10:57 PM
blue00WS6's Avatar
Angry Need help... PLEASE..... Anyone
Ok... I am having some problems with the car and I don't know why. Here we go... Thursday, my voltage was low so I had the battery and alternator checked. Was told the alternator was going out and needed to be replaced. So I replace it with a new one. Jumped the car (so it would start) and meter was still low. Pulled the battery out, took it and had it checked... was told the battery was bad, so I replaced it. Put the new one in, meter is still low. Drove the car up to autozone, said the battery was good. But when I shut the car off and then started it again, the lil machine they have, said the starter, alternator, & battery needed to be checked/replaced. So, $215 later, I still have a problem. The guy said the only thing he can think of is an electrical problem! So, what do I do? Can anyone help me out? Please.........
Old 07-03-2005, 11:02 PM
kpowr82's Avatar
How long ago did you put that ASP Crank Pulley on there? There is also an alternator pulley you can buy to speed up charging, correct?
I'm willing to bet that if the cam and pulley listed in your sig are recent additions, it may have to do with a poor charging situation.
Old 07-03-2005, 11:15 PM
blue00WS6's Avatar
The cam and pulley were installed back in April.. so 3 months ago! All of this just happened within the past week! I quit driving the car everyday to work, and drove my other car. I only drove the car on the weekends and have never had any kind of problems, till now.
Old 07-03-2005, 11:23 PM
ss rally red's Avatar
Make sure you have all the wires hooked up to the back of the alternator.
Old 07-04-2005, 01:03 PM
blue00WS6's Avatar
There is only one wire that goes to the alternator. When I was still having problems, I even took the alternator out and put it back in.
Old 07-04-2005, 01:42 PM
oange ss's Avatar
remove all grounds in engine bay ( 1 on pass fender well, 2 on radiator support , 1 on driver fender well ).....remove paint from surface directly under ground eyelet, thoroughly clean eyelets with sand paper, reinstall grounds......that should help
Old 07-04-2005, 02:40 PM
shouldaboughttheZ's Avatar
Hate to tell ya, but there is 2 wires. One connector (with one wire) and one big wire (that bolts to the back). Did you hook up the connector wire?
Old 07-04-2005, 06:25 PM
oange ss's Avatar
yes, the small wire with the connector is the exciter wire
Old 07-04-2005, 06:48 PM
LS1ownzYOU's Avatar
I was thinking the same thing, but then i saw you have an m6 so i dont think that the crank pulley would really effect you that much... but wut do i know? lol
Old 07-04-2005, 08:20 PM
blue00WS6's Avatar
Are you serious!!!! I saw that wire hanging there and I didn't know what that was for or where it went!!!
Old 07-04-2005, 08:36 PM
Tranzaman00's Avatar
Also be sure you fully recharge your battery when doing a new alt. install
Old 07-04-2005, 09:51 PM
Well there ya go
Old 07-05-2005, 09:00 AM
blue00WS6's Avatar
So where does that connecter go? Does it plug in to the alternator?
Old 07-05-2005, 10:35 AM
yes it plugs into the alternator. Unfortunately you will have to pull it out gain to do this. If you are underneath the car, you will have to feel for the plug in on the alternator. Or pull the alternator and look at it from the top.
Bet your problem is solved then.
Old 07-05-2005, 02:09 PM
blue00WS6's Avatar
I bet it will solve the problem. One more question. For this connector, was I supposed to take anything off the old aternator, to put on the new one for the connector to plug in to?
Old 07-05-2005, 03:03 PM
oange ss's Avatar
no ,the connector is part of the alternator itself
Old 07-05-2005, 03:16 PM
blue00WS6's Avatar
sweet!! thanks guy's! I really appreciate all the info that everyone has provided! Hopefully that will fix my problem and then I won't have to stress over it anymore!
Old 07-05-2005, 03:45 PM
let us know.
Old 07-05-2005, 09:00 PM
blue00WS6's Avatar
Well the problem is fixed. Thank to you guy's, I have solved my problem! I forgot to hook up the exciter wire on the alternator. Actually I didn't even know that there were 2 wires! But everything is good now! Thanks everyone for your help and info you provided!
James
