Need GM Part #
Old 07-04-2005, 08:29 PM
JF WS6's Avatar
Default Need GM Part #
Hey guys, anyone know off the top of their head what the part # is for the hex bolt? I know what size it is (12X1.5P), but I can't find one with the right thread pitch anywhere. TIA.
Old 07-04-2005, 08:41 PM
Restricted User
CAT3's Avatar
Home Depot doesnt have one? Odd, unless they are out, I got a hex bolt to replace the allen head one pictured above, same length and dia. just different means of fastening. Good luck if you dont find locally.
Charlie
Old 07-04-2005, 08:42 PM
DWillTA's Avatar
LS1 rear coolant bolts (on back of heads) = 11514008
https://ls1tech.com/forums/showpost....6&postcount=15
Hope that helps.
Old 07-04-2005, 10:10 PM
JF WS6's Avatar
Charlie
Did you find one with the correct thread pitch? I can find 1.25 and 1.75 thread pitch bolts, but none in the correct 1.5.
I'll bet if you got one at Home Depot it was the standard 1.75. I guess it may have threaded in, but you may have boogered up the threads in the head doing that.
Old 07-04-2005, 10:19 PM
JF WS6's Avatar
Hope that helps.
Thanks for the help, but I don't think that's the right one.... JMX has that part # listed as this:
Bolt 11514008 engine C5 Fbody GTO Throttle body to intake manifold bolt. 3 Needed. M6x1.0x30mm
I know that isn't the right size....
Old 07-04-2005, 10:24 PM
JF WS6's Avatar
I don't care where I get a bolt this size as long as I can get one. If anyone has a spare one around from a junk pair of heads I'll buy it....
Never thought I'd have such a hard time finding 1 stupid bolt.
Old 07-05-2005, 01:19 AM
TAF Motorsports's Avatar
GM PArts Direct has them for 3.49. Part# 12553191
Old 07-05-2005, 10:34 AM
JF WS6's Avatar
Thanks for the info dude!
Quick Reply: Need GM Part #
