LS2 based 408 or Iron Block 408 ???
Old 07-09-2005, 01:08 PM
FCar2000TA's Avatar
Default LS2 based 408 or Iron Block 408 ???
Inputs??? I know that the knock sensors work "in theory" if you extend the factory LS1 knock sensors... but have they been proven???
Old 07-09-2005, 01:36 PM
obZidian's Avatar
i think the ls2 will get you a 402...
but if your asking for preferences.....it all depends on wat you will be throwing at it....
I would get the iron just for a little piece of mind and the extra, though minimal, cubes.
Im not sure on the knock sensors....there tons of 402 ls2 here...check the dyno section and post a question in one of those threads of just contact on of the shops directly.
Old 07-09-2005, 01:58 PM
FCar2000TA's Avatar
I just read that the LS1 knock sensors can be put into the LS2 block on the passanger side with a little work, but they do work.
Old 07-09-2005, 03:45 PM
DONAIMIAN's Avatar
If your funds allows the aluminum block id go with that.
Old 07-09-2005, 04:52 PM
FCar2000TA's Avatar
I dunno.. the knock sensors in the side of the motor instead of in the valley still kind of concerns me. I dunno.
Old 07-09-2005, 05:44 PM
Procircuit155's Avatar
there's alot of cars out there running knock sensors on the sides of the block
Old 07-10-2005, 03:24 PM
FCar2000TA's Avatar
eh I just have a really bad habit of being overly paranoid when it comes to large $$$ mods to my car. I want to buy the right stuff that will work for a long time.
Old 07-11-2005, 01:01 PM
1CAMWNDR's Avatar
You really do not need a 402/408. Get a built aluminum block 347 or at most a 383. That will make more power than you can handle Eric. And you told me when you bought this car that you didn't want to do anything "major" to the engine . Not a strip car but maybe twice a year? You want something that will be reliable on the street for several years? The 408 is really a race motor. You would need a huge cam and killer heads to use the extra cubes. Fuel economy would SUCK! I just think a 347 or 383 would be a much better street motor for you.
Fix the transmission.
Buy a rearend.
Get some drag radials .
Then see what you need.
Old 07-11-2005, 04:05 PM
FCar2000TA's Avatar
Buy a rearend.
Get some drag radials.
Like I said.... that will happen first. But if I the 402/408 (no core charge) is less than $1K more than a built 347... why not just get the big stuff.
BTW... I change my mind a lot... haven't you learned that in the past 28 yrs? HAHAHA!!!!
How'd you guys do with the little thunder storm this weekend?
Old 07-11-2005, 04:12 PM
BUYAMERICAN's Avatar
My N/a 427 gets 31 mpg. on the highway at 80 mph and will be putting down close to 600 rwhp on the next tune.
Old 07-11-2005, 04:15 PM
FCar2000TA's Avatar
Buy a rearend.
The Iron Block 402/408 is almost the same price (if you consider core charges) as the 382/383.
Old 07-11-2005, 04:27 PM
~JOSHUA's Avatar
Why would you want iron which weighs 100lbs. more than the LS2 block? Unless you're really into big nitrous or boost- WHY?
Old 07-11-2005, 06:59 PM
1CAMWNDR's Avatar
The little storm didn't do too much here. I feel for the folks in Pensacola again.
If you think you can handle the big motor, knock yourself out. You might luck out like BUYAMERICAN did and have a half decent street motor that gets good miledge.
This is really just a ploy by me to keep you slower than me .
Old 07-12-2005, 03:55 PM
FCar2000TA's Avatar
HAHAHAHA!!!!!! where's the 1up sound from Super Mario Bros when you need it.
FCar2000TA's Avatar
I'm worried about the knock sensor stuff... placement, computer reading correctly... etc
Old 07-13-2005, 03:33 AM
WOT
WOT's Avatar
i would go the iron 408 route. but then again... i am addicted to nitrous and haven't dealt too much with the ls2's. i have heard of fixing the knock sensor problems and things working with the conversion... but i have seen too many nasty iron 408's to look else where.
i take that back... i just read your sig. i would look into a rear end and finishing out a good suspension. i went the power route first and hated not having the suspension and durability to handle it. but then again... it was fun grenading the 10 bolt!
Old 07-13-2005, 08:53 AM
FCar2000TA's Avatar
All I have left for the suspenssion is shocks and springs (BMR torque arm relocator if that counts as suspenssion).
I will be getting a rearend before the motor... Basically...
Stage I - (August)
New Clutch (probably Ram)
Rebuild Tranny to handle 600 ft/lbs of torque
StageII - (September)
12 bolt or 9" rearend
StageIII -(October)
motor
Maybe between now and October, the LS2's will be proven to work perfectly with LS1 knock sensors.
Old 07-13-2005, 09:04 AM
SLED28's Avatar
We just did our first in house LS2 conversion, and the LS1 knock sensors work no problem.
