Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
lifter hold up tool (5/16" wood dowel, $1.59 from home depot)
Old 07-10-2005, 08:58 AM
Closed ex-Sponsor Account
SteveDoten@ARH's Avatar
Lightbulb lifter hold up tool (5/16" wood dowel, $1.59 from home depot)
helped out w/ a cam install last night(234/240 598/608 114LSA Competition Cams custom grind from 21MC)cut the dowels to 22" in length and spun the cam before installing dowels, also ground the front of dowel to a taper(spun on concrete like sharpening a pencil), dowels went right in-'01 c5 w/ 40k miles
TOTAL COST OF CAM INSTALL TOOL=$1.59
used the autozone 3 arm puller on the crank bal. w/ stock bolt for removal, would help to have the bal. bolt 1" longer, now waiting for a valve spring rem. tool from TR; this "tools" section is awesome, corvetteforum is lacking on the "tech" stuff
pic of hi-tech lifter tool http://forums.corvetteforum.com/show...3&forum_id=103
Old 07-10-2005, 10:47 AM
2000blackta's Avatar
those are what i used as well. beats the hell out of spending $90+.
Old 07-11-2005, 05:22 PM
Z'mnypit's Avatar
Used the same thing, but it was .87 after tax at ACE. Cant beat that.
Old 07-11-2005, 10:39 PM
is this common knowledge? i don't know why people are spending 80 bucs on machine metal rods? ls1tech beats the sheat out of corvetteforum when it comes to stuff like this
Old 07-14-2005, 01:43 PM
Dumb Ass Vette Moderator
ls1290's Avatar
Did you notice where the post he referred to is from
Keith
Old 07-14-2005, 03:24 PM
redbandit98's Avatar
yep...ive used mine several times in the past...i used metal rods to make mine though..
Old 07-20-2005, 02:15 PM
SgtB's Avatar
How much did you have to grind on the one end???I am curious becaue I am doinmg mine soon.
Old 07-20-2005, 04:26 PM
~JOSHUA's Avatar
I used 1/4" aluminum... it'll flex. I didn't have to flat spot anything , I just tapered the tip with a file.
Old 07-21-2005, 07:13 AM
SgtB's Avatar
Can you guys send me pics of the tapering??
Old 07-25-2005, 03:52 PM
Z'mnypit's Avatar
All you have to do is sharpen the end like a pencil. Not to a sharp point. But you get the idea. I used a pocket knife on mine.
Old 07-26-2005, 07:00 AM
SgtB's Avatar
Anybody have more pics?
Old 10-01-2005, 03:16 PM
yekta's Avatar
subscribing, sweet
Old 10-01-2005, 04:39 PM
LS1powerhouse02's Avatar
I used wooden dowels on my cam install also....couldn't have been cheaper or easier....my friend did his cam install first and used the pen magnet method and ended up dropping a lifter! By far the dowels are the best way to go IMO. As far as tapering the end of the wooden dowels all i did was scraped it on the concrete driveway to make it look like a dull pencil end. It's really not that hard...don't look so deep into it! Good luck!
