true duals
Old 07-14-2005, 05:49 AM
CNTLSE 1's Avatar
Default true duals
I was wanting to see if anybody has true duals ran all the way out the back under the axle? If you do how is your clearance with or without lowering springs. Also pictures would be great if you have them.
Old 07-14-2005, 06:47 AM
mikemodano9c's Avatar
search...there are a few posts with pics of under the axle duals
Old 07-14-2005, 06:53 PM
CNTLSE 1's Avatar
Nobody HUH?
Old 07-15-2005, 08:41 AM
rufretic's Avatar
Mine should be done this weekend. I already had it all up to check the ground clearance and it looks real good. I took it all back down because I'm waiting on a mandrel bent 90 for the one header, so no pics. From the x back looked good though. My car is not lowered in back but I have about 4-5 inches of clearance at the lowest point, which is plenty for me.
Old 07-15-2005, 10:30 AM
slt200mph's Avatar
Try using the search function..there have been dozens of the under and over the axle systems photos posted on this forum
Old 07-15-2005, 10:34 AM
Kleeborp the Moderator™
MeentSS02's Avatar
Nope. Nobody has ever done this. They've never done it over the axle either. You'd be the first. Go for it!!!
Old 07-15-2005, 11:06 AM
Ws6ik_2000's Avatar
True duals over the axle with 1 1/2 drop.
Attached Thumbnails true duals-0063048-r1-028-12a.jpg   true duals-0063048-r1-030-13a.jpg   true duals-0063048-r1-034-15a.jpg   true duals-0063048-r1-032-14a.jpg
Old 07-15-2005, 11:09 AM
UnZFeat'd's Avatar
wow that looks pretty low, does it take speed bumps alright?
Old 07-15-2005, 11:12 AM
Ws6ik_2000's Avatar
as long as i go slow it doesn't rub over speed bumps. its not as bad as it looks though.
Old 07-15-2005, 12:47 PM
Y2K SS's Avatar
you guys need to go over the axles, I have it and with a drop you'll sometimes here a thump as it hits the floor pan. If you go under the axles you have to consider that when you go fast over a hump your suspension will expand and the exhaust doesn't you will hit the exhaust on the rear and bend something. Just something to think about.
Old 07-15-2005, 09:47 PM
rufretic's Avatar
Not if you mount it while its on jack stands. Thats what I'm doing and after the car is down, I have 4-5" clearance. I don't need a lot of clearance because I don't drive over curbs or speed bumps. If you try to install it this way, you may not get the same clearance as me because I have hal shocks. They don't let the axle drop as much so they helped me.
Old 07-16-2005, 07:35 AM
CNTLSE 1's Avatar
Did you have to do anything special to get it over both sides? Also what size pipe did you use and if you don't mind me asking how much did you pay for it?
Old 07-16-2005, 12:50 PM
rufretic's Avatar
I used 3" stainless steel from the headers to the X then 2.5 the rest of the way. I got most the stuff off ebay. I think its like $39 per 5'. You need a bender or a lot of prebent elbows, they are $39-$49 each so it can get expensive. I used a bender from work and still needed a coulpe of the sharp turns prebent. I'm in the process of finishing right now, I'll post pics when I'm done.
Old 07-16-2005, 07:53 PM
CNTLSE 1's Avatar
How about you ws6ik_2000
Old 07-24-2005, 11:42 AM
Ws6ik_2000's Avatar
3 inch x to 3 inch bullet mufflers then 2.5 inch pipe over the axle. I got the x pipe for $100 from speed inc, got the bullets from summit for $40, and got the welding and bending done at a local exhaust shop. Total cost was about $250 sorry about the late post
Old 07-24-2005, 11:07 PM
rufretic's Avatar
I finally finished mine this weekend. I'm going to start a new thread but heres a link to some pics. http://community.webshots.com/user/rufretic
