True Duals ?
Old 07-27-2005, 01:38 PM
sdbrown84's Avatar
Default True Duals ?
Why dont most people go over the axel on both the driver side and the passenger side for TD's over the axel?
Are the ABS brake lines and wiring in the way on the driver's side? Is there a clearance issue?
Old 07-27-2005, 01:43 PM
777's Avatar
Not enough clearance. There is the Upper panhard bar and the fuel lines. People can go over both sides w/2.5" piping but it's still really close. They will usually flip the fuel line brackets over and that gives enough clearance on the lines. You still have the upper PHB though.
Old 07-27-2005, 02:14 PM
TINKRD's Avatar
BMR makes an upper PHB for this. Although, i've never personally seen anyone use them.
Old 07-27-2005, 02:15 PM
TINKRD's Avatar
This kit replaces the upper panhard rod support and relocates the panhard rod allowing enough room for up to dual 3" exhaust routing over the axle. Heavy duty tubular upper panhard rod support mounts in the original panhard rod location. New heavy duty brackets bolt to existing mounting holes and lower the panhard rod while maintaining the correct geometry. No welding or drilling required. Available standard in your color choice of red or black powdercoat, additional colors also available by
Old 07-27-2005, 04:36 PM
shawn's SS's Avatar
The BMR upper PHB is made for dual pipes over the pass side.
Old 07-28-2005, 09:11 AM
Lane's Avatar
* non-sponsor link removed.
Old 07-28-2005, 09:15 AM
lees02WS6's Avatar
that's a damn nice dual setup Lane!
Old 07-28-2005, 09:31 AM
TINKRD's Avatar
damn Lane, that looks bad ***.
Old 07-28-2005, 09:52 AM
777's Avatar
That's typical work from Lane . As said above the BMR upper PHB is for duals over the pass. side. Lane is that 2.5" piping, or 3"?
Old 07-28-2005, 10:47 AM
Lane's Avatar
I've done both 2.5" and 3". Most systems aren't like the ones in the pic though - which we used a custom built Bassani muffler. Normally, it's just tail-pipes built off of dumped systems with bullet mufflers before the axle.
Thanks for the compliments.
