True Duals ?
Are the ABS brake lines and wiring in the way on the driver's side? Is there a clearance issue?
BMR makes an upper PHB for this. Although, i've never personally seen anyone use them.
This kit replaces the upper panhard rod support and relocates the panhard rod allowing enough room for up to dual 3" exhaust routing over the axle. Heavy duty tubular upper panhard rod support mounts in the original panhard rod location. New heavy duty brackets bolt to existing mounting holes and lower the panhard rod while maintaining the correct geometry. No welding or drilling required. Available standard in your color choice of red or black powdercoat, additional colors also available by
. As said above the BMR upper PHB is for duals over the pass. side. Lane is that 2.5" piping, or 3"?Thanks for the compliments.
