header question
Old 08-08-2005, 04:11 PM
onefastredbird's Avatar
Default header question
im thinking on getting the MAC 01-02 LS1 Header System with Y-Pipe, No Catalytics and no egr.i want to put them on myself but i dont think there is any room for me to get the header bolts off.im just wanting to know is it possible for me to do it myself or am i going to have to take it somewhere.
Old 08-08-2005, 04:34 PM
jaberwaki's Avatar
header are easly done at home if .
1. you are not easly frustraited
2. you have a pretty good basic tool set.
3. you have a good jack
4. you have some 6X6 wood laying around...
headers are best installed from the bottom, do a search you will find insall instructions also check out the install sites, you might find a whole write up there
and if you do not need emmisions stuff then skip the mid legths and get longtubes.
Old 08-08-2005, 04:57 PM
jaberwaki's Avatar
heres one
http://www.geocities.com/foff667/98Camaropg4.html
Old 08-08-2005, 06:19 PM
Default wish me luck
thanks,wish me luck and if you think of anything to tell before i get started just reply or e-mail me.
Old 08-08-2005, 07:47 PM
green28's Avatar
Just remember to have everything you need before you start. I was gonna reuse the old gaskets, but got new ones instead, which took a day to get. I'm still not done with mine after a week, because the place I ordered from shipped me an LT1 y-pipe instead of an LS1 y-pipe. And most of all have some patience, something I was short on while I was working on mine.
Old 08-09-2005, 09:47 AM
mrbobo's Avatar
Poly motor mounts go in much easier when the exhaust is off.. do it when you do your header install. And you will want to have 10mm (and 11mm if you use stage 8 header bolts) gear wrenches. I like the flex heads.
Old 08-30-2005, 08:00 PM
DirtyJohn's Avatar
Do you guys think it would be safe to use cinder blocks in place of the 6x6's?
I just got a quote for 500$ to put the headers in and they wouldn't even want me in the garage while they did it. I don't want to just hand off my car to have everything done for me if I can at least try it on my own.
I think I can get my QTPs' on if I can get the car in the air.
Old 08-30-2005, 08:14 PM
jaberwaki's Avatar
i NEVER leave my cars alone in a shope where i dont know the mechanics
