what to do with 3 grand
I have a BONE STOCK 2001 Pontiac Trans Am WS6 M6. What would you guys do to it with 3 grand? I am lookign at going n/a down the road here, but what should I do first. Let me hear some suggestions guys, thanks alot
Originally Posted by ashzero
hpe big box of goodies
jrp is right, $3k wont' get you as far as you may think. This game is expensive.
If you plan to take it to the drag strip much your best start is a GOOD clutch and rear end, but those two things alone will easily use your entire $3k budget. Depending on which clutch you get, etc, you could spend about $4k on clutch/rear end.
This is all I will recomend, unless you get more specific with your end goals. For a fun/powerfull street car I'd get all the power bolt-ons, subframe connectors, new clutch, and then either suspension mods to make it handle better or a cam. It all depends on what, exactly, you want to do with the car.
Originally Posted by gollum
Invest in government bonds? Just kidding.
Very Simple: GMMG exhaust, Dry nitrous, 3.73 gear , Crane handheld tuner.
long tubes 300
2.5 or 3in true duals 400
lid w/ filter 100
ported TB - homemade
stage 2 ls6 heads w/ cam and all goodies - 2000
dyno tune - 200
dont get a better clutch until your stocker gives out
lid w/ filter 100
dyno tune - 200
Originally Posted by JustAnIlluzion
long tubes 300
lid w/ filter 100
dyno tune - 200
lid w/ filter 100
dyno tune - 200
long tubes 300
lid w/ filter 100
dyno tune - 200
lid w/ filter 100
dyno tune - 200
Where can you get a dyno tune for $200?
No offense, but you are not going to get away with all that stuff for $3k. There are a lot of little things that will add to that, along with the questionable prices quoted.
Ahhh, patriot peformance LS6 "style" heads.
Personally I'd stay away from PP. For budget heads I kinda like TEA.
Reading all the links in jrp's sig will help you quite a bit.
