New LS1 Owners - Newbie Tech - which should i do first??
View Full Version : which should i do first??
Z28LS1camaroguy
08-18-2005, 01:10 AM
ok i am set on these two setups and i dont know which to do first, should i go with coated pacesetter long tube headers and TSP offroad Y. or should i do the Fuddle racing 3500 stall and 3.73 gears first, help me make my decision and comments on the choices. i am getting a cutout installed right before the muffler so the flowmaster will just be for looks mainly lol.
Z28LS1camaroguy
08-18-2005, 01:50 AM
also do i need the 3 inch cutout or can i fit a 3.5 inch cutout on my flowmaster catback I pipe?
Cop Car
08-18-2005, 03:19 AM
what rear gear do you have? if you have 3.23s id say just put a girdle on it and stall it....if you have 2.73s deffinatly get gears, then stall it..
just my .02
Tx02ssm
08-18-2005, 07:38 AM
My son just installed 4:10's on his 00 T/A and it is friggin awesome - my next mod will definitely be 4:10 gears with a girdle.......I would suggest you not spend your time/money on 3:73's unless you really care about 130mph+......... And yeah, go with the convo+gears. Changing how your auto shifts makes a huge diff in driver satisfaction/response time to WOT and several other factors that can only be felt by seat-of-the-pants method. I used to own a 99 Lighting, and the best mod I made on that truck was a 60buck valve replacement piece that went into the tranny and changed the shift points - 1st to 2nd would hit like a ton of bricks and I could get a pretty serious chirp 2nd to 3rd after that mod. It added no HP, but made a huge difference in how I felt about the truck off the line. Good luck w/mods - stevet
EPP
08-18-2005, 08:00 AM
http://www.exoticperformanceplus.com/services.php?service=66
The above link has a lot of ideas on what should be done for these cars. Bob
BlueSix
08-18-2005, 09:32 AM
Go with the converter first.
If you already have 3.23 gears then don't waste your time on doing 3.73's. Take that money and put it somewhere else.
Be sure to get a good tranny cooler.
Z28LS1camaroguy
08-18-2005, 12:36 PM
i have the 2.73 gears unfortunatly and definantly need more power in the rear, want to be able to smoke em all the time lol.
Cop Car
08-18-2005, 03:40 PM
Deff stall, cover and 3.73s then...
3.73s really woke up my friends 2.73 car...
jaberwaki
08-18-2005, 04:19 PM
stall and gears(everyone already said) and you want a 3" cutout not 3.5
blkZ28spt
08-18-2005, 04:49 PM
According to your sig you already have both. :confused:
For a purely performance gain get the converter. Converter, shift kit, trans cooler, trans temp gauge, some basic PCM editing of shift points, subframe connectors and drag radials. Will be a night and day difference. :D
The gears are not nearly as important as the converter, so if you can't get the gears yet don't sweat it as they won't net more than anyway 0.15.
I did my headers/duals before converter cause I was all about the awsome sound, but the converter is a much bigger SOTP difference.
PS: Where in Indiana are you located?
ULTIMATEORANGESS
08-18-2005, 07:30 PM
i went with a TC and gears before LTs.
Z28LS1camaroguy
08-19-2005, 12:27 AM
ok well i think i will get the fuddle torque converter and GM 3.73 gears first and then go with the exhaust mods. also how much does it cost to get the converter and gears installed??
