Head Gaskets????? Need quick answer
Old 08-30-2005, 11:27 AM
HASTINGSRJ's Avatar
Default Head Gaskets????? Need quick answer
So I put a set of head gaskets on the new heads, never ran the motor, but did tourqe them down all the way. Are these safe to use again????? If not, I gotta get my *** over to the chevy dealer really quick. Thanks for any input.....
Rob
Old 08-30-2005, 11:49 AM
SideStep's Avatar
What type of head gasket??? MLS? If so, I would use it again. If it is a composite gasket all bets are off, it might work, it might not...
Good Luck
Old 08-30-2005, 12:04 PM
HASTINGSRJ's Avatar
they are stock GM head gaskets.....
Old 08-30-2005, 12:31 PM
xfactor_pitbulls's Avatar
Good Luck
I concur, MLS yes, composite no way. The comp gasket is meant to seal down when the bolts are torqued. If you are not sure which gasket you have it is very apparent when you pull the heads back off. If there is debris left everywhere its the composite.
Brandon
Old 08-30-2005, 12:35 PM
HASTINGSRJ's Avatar
no debris anywhere.....and the gaskets are still intact....
Old 08-30-2005, 12:37 PM
If you left your block surface CLEAN and the gasket is 100% still intact with no damage I say run it.
Brandon
Old 08-30-2005, 01:30 PM
HASTINGSRJ's Avatar
Sweet, thats less money I gotta spend.....I already spent enough, towing the car, getting work done for no results....and now on a new block
Old 08-30-2005, 02:07 PM
racecar's Avatar
I have been in that same situation, did not run the motor, but had to take it apart.
I used new head gaskets. Maybe I'm paranoid, but I think there is something sacred about torqueing the head and crushing the gasket to conform to the head?
I would buy new.
Old 08-30-2005, 03:24 PM
robertbartsch's Avatar
I would buy new gaskets also. Its just not worth the trouble. You may have to take it apart again and risk busting another head bolt ot two...
Are you using ARP studs yet?
