CAm IDLE RPM
Old 08-31-2005, 01:19 PM
00pewterWS6TA's Avatar
Default CAm IDLE RPM
i'm kinda new to cams,but i was lookin in to gettin a tr 224 112 lsa. i see alot og guys have them and sound really good, but what rpm are you guys idleing at. i want a mean lopey sound and i heard if you set the rpms lower the louder the sound. is that true? any input would help. thanks
Old 08-31-2005, 01:48 PM
conan's Avatar
I had that same cam in old setup after a tune it idled @750 sounded real good too.
Old 08-31-2005, 02:04 PM
Xtnct00WS6's Avatar
The lower the rpm your car idles at, the meaner it sounds. It won't be louder though. It'll have a more distinct "cammed car" sound with the rpms low. The problem with that is the car will have a tendency to surge so getting off the line will be a huge challenge.
I have a TR 224/224 114 and my car idles at around 900. It sounds great and performs well too!
Old 08-31-2005, 03:47 PM
Z28_Ninja's Avatar
i have a custom grind 224/224 567/567 on a 112 and the idle is set at ~650 and i have no surge or anything and she sounds mean. also that is in an a4 for what its worth
Old 08-31-2005, 09:36 PM
Ragtop 99's Avatar
650 rpm idle, that's some good tuning.
Old 08-31-2005, 10:33 PM
Ryan02SS's Avatar
I have mine at 900rpms w AC off & 950 on. Has a nice short chop and thru the cats you really have to have a trained ear to notice a cam. I had it at the stock idle setting and it was a little more lopey but I prefer the higher idle speed.
Old 08-31-2005, 10:44 PM
TOZ
TOZ's Avatar
Mine still stock idle which I think is in the 800s and sounds good. And it`s a 114LSA
You can hear it here: http://www.sffba.net/toz/toz/camshort.wmv
Old 09-01-2005, 12:15 AM
DONAIMIAN's Avatar
my 221/221 112 idles at 900 and you can deff tell its a cam in there.
Old 09-01-2005, 02:11 PM
MannyZ28's Avatar
After initial install, my idle was at 900 rpm (I have a M6). During tuning we lowered it to 800 and it sounds quite a bit meaner. My cam is on a 112 (see sig), and either at 900 or 800, you definitely know there is a cam in there.
Manny
Old 09-01-2005, 02:27 PM
2001CamaroGuy's Avatar
had 650 RPM in my M6/3.73 gear daily driver for a while......it worked but was really touchy at times..........the stock M6's 800RPM idle speed works REALLY good with that cam.....
Old 09-01-2005, 02:33 PM
GuitsBoy's Avatar
my f13 idles fine at 850.
Old 09-01-2005, 03:59 PM
jmm98LS1's Avatar
After lotsa tuning mine idles at 650 no problem. Sounds sick as hell
Old 09-01-2005, 06:37 PM
FstBlkz28's Avatar
My car is tuned right now to run at 900 w/ my tr230 so that it wouldn't surge much if at all when I had the max a/c on and coming to a stop. However, after going out and playing w/ my EFIlive pro today playin w/ idle I found that 775 works just as well, but you have to run the regular a/c. Not the max. But hell for as mean as it sounds at 775, i'll take just using the a/c
Old 09-01-2005, 07:35 PM
DONAIMIAN's Avatar
for whats its worth, I have an aluminum flywheel and it dosent like the low idle.
Old 09-01-2005, 09:00 PM
see now I have an aluminum flywheel and didn't notice any change in the idle.........
Old 09-01-2005, 09:50 PM
BriancWS6's Avatar
When I had my pewter car, A4, with the TSP 225/225 .589.589 on 112lsa, it idled at 675 no problem, sounded sweet!
