Stealth cam owners......Need help!
Old 09-06-2005, 12:29 PM
Pimpium57's Avatar
Default Stealth cam owners......Need help!
I've been considering a LPE GT2-3 cam for the longest time, but many of you suggested one of the MTI Stealth cams (or similar spec'ed cams). I know the Stealths would put out a bit more power, but my attraction to the GT2-3 was a DEAD stock idle. Does anyone have a Stealth cam w/ full exhaust AND a completely stock sounding idle?
Alotta guys say, "it's all in the tune".......and to go for a cheaTR or Stealth cam, but if it will be lopier than a GT2-3, then it's not for me.
Thanks!
Old 09-06-2005, 01:07 PM
SLP4CamaroSS's Avatar
same here im in the same boat im looking at the gt2-3 cam but othere say go with the stealth or the cheatr
Old 09-06-2005, 01:09 PM
Bryan @ Speed Inc.'s Avatar
i have the MTI stealth 2. the cam makes good power........ and with a 700/750 rpm idle, it's got a very small beat to it.... 800 rpm idle sounds dead stock w/ full exhaust.
Old 09-06-2005, 01:14 PM
have you dynoed yet how was your gain with that cam
Old 09-06-2005, 01:25 PM
well i put it in a big 402 stroker......... so no good comparisons. made 440+ rwhp w/ a fast 90/90 set up.
^^^ through a 6spd, steel flywheel, 12 bolt w/ 33 spline axles and a posi
Old 09-06-2005, 01:39 PM
Pimpium57's Avatar
The 402's gonna make a big diff. compared to a stock 346....
Old 09-06-2005, 02:43 PM
PREDATOR-Z's Avatar
Stealth II here, 434rwhp with PRC stage 2.5, 5.3L heads + boltons etc...
Old 09-06-2005, 03:57 PM
Rob
Rob's Avatar
The GT2-3 idles like bone stock even with stock tuning. Idles like stock after tuning...and made quite a bit more
The only Stealth II I've heard of was in a GTO and it loped. Worse when it was cold and then smoothed out to slightly noticeable.
