Amp rack for large amp.
I was looking at the subthump amp racks but my amp is 17.7"x9.25"x2.36". It wouldn't be able to mount to either side of it.(right side of hatch latch or left side) And I can't tell if the spot under the latch is wide enough(top to bottom) to mount the amp centered under the latch. Any comments or suggestions?
do what i did.....
http://community.webshots.com/photo/...33518730WtRFew
mount it across the entire back.
Ok, here's the promised pics.
Two notes.
1) These are huge images (some nearly 1.5 MB in size), dialup users beware.
2) If you link directly, they will be removed. Please link to this thread.
http://home.comcast.net/~zx1100e5/pics/100_1136.JPG Driver sail panel
http://home.comcast.net/~zx1100e5/pics/100_1137.JPG Passenger sail panel 1
http://home.comcast.net/~zx1100e5/pics/100_1138.JPG Passenger sail panel 2
http://home.comcast.net/~zx1100e5/pics/100_1139.JPG Passenger sail panel cross over
http://home.comcast.net/~zx1100e5/pics/100_1140.JPG amp rack 1
http://home.comcast.net/~zx1100e5/pics/100_1141.JPG amp rack 2
http://home.comcast.net/~zx1100e5/pics/100_1142.JPG amp rack 3
http://home.comcast.net/~zx1100e5/pics/100_1143.JPG amp rack 4
EDIT: After all this work, I still can't fit the pass ttop. The sub is in the way. It will not slide down deep enough into the well to be locked in place.
Edit2: Previous pics http://home.comcast.net/~zx1100e5/pics/
Two notes.
Dream,
Vertical mounting would work too, but also consider how easy adjustments will be.
You might be able to mount both horizontally, but offset.
How big is your 2nd amp? Or are both the dimensions posted above?
They are both about the same size. If I ount them vertically they will actually be easier to make adjustments to. I'll just mount them with the frequency controls facing up towards the hatch.
