6.0 heads
Well what are your goals? Do you just want to do a 'budget thin' or are you wanting a more lasting idea?
If you are just using a stock block, and want heads for a lil lower compression, then yeah, just throw some springs on them.
If you are building a motor there is no reason to get cheap now, ports them springs,a nd possibly larger exhaust valves.
all in what you want to do
ed
ed
I would kinda like to go cheap now as these will be on my stock 5.7 for now then a iron block not sure yet though. I dont want to do to much to them and lose alot of power on my engine the way it sits now. thanks guys for the help what size exhaust valves should i use and should i leave the intake valves stock?
