Fuel Pressure Guages
Old 09-14-2005, 11:03 PM
Spenser309's Avatar
Default Fuel Pressure Guages
while taking a look online i noticed that mechanical Fuel Pressure Guages cost 20 bucks and electric cost around 250. Why?
Is there any way to put a mech fuel pressure inside the cabin or is it impossible?
Old 09-14-2005, 11:10 PM
Restricted User
CAT3's Avatar
It is possible, just use a longer -3 line to it, but the issue is you would have fuel flowing inside the cabin and thats not legal by NHRA, IHRA, most states laws and is pretty silly. You can find some nice electric gauges for around $150. Worth it? I think so, answers half the questions when a car wont start!
Old 09-14-2005, 11:11 PM
Spenser309's Avatar
where for $150? that actually sounds reasonable vs $250.
Old 09-14-2005, 11:19 PM
Restricted User
CAT3's Avatar
I believe Stewart Warner gauges, and let me get some links going here....
or this from Dyno Tune Performance...
http://www.dynotunenitrous.com/store...p?idproduct=19
Old 09-14-2005, 11:33 PM
Spenser309's Avatar
that was $175? could i use this http://www.tbyrne.com/ls1catalog.html in the guages section only $100 bucks for the sender and the guage.
Old 09-15-2005, 05:18 AM
XTrooper's Avatar
I'm not crazy about digital gauges, but yes, that gauge and sending unit for ~$105 should work.
Old 09-15-2005, 08:29 PM
Spenser309's Avatar
okthanks
Old 09-16-2005, 12:40 AM
cyipher's Avatar
You can use a mech gauge but its very advisible to use an isolator kit
Old 09-16-2005, 11:56 AM
LS1TECH Sponsor
DynotuneN2O's Avatar
Only issue with the mechanical gauges with the cheaper sending units is that they are typically off by 0-15psi at higher fuel pressures. If your just looking to see if you have fuel pressure they work fine. If your running a dry nitrous kit and looking for fuel pressure to rise, its nice to have repeatablity.
Cheers
Dan
