Fuel Pressure Guages
Old Sep 14, 2005 | 11:03 PM
Spenser309's Avatar
Default Fuel Pressure Guages
while taking a look online i noticed that mechanical Fuel Pressure Guages cost 20 bucks and electric cost around 250. Why?
Is there any way to put a mech fuel pressure inside the cabin or is it impossible?
Old Sep 14, 2005 | 11:10 PM
CAT3's Avatar
Restricted User
It is possible, just use a longer -3 line to it, but the issue is you would have fuel flowing inside the cabin and thats not legal by NHRA, IHRA, most states laws and is pretty silly. You can find some nice electric gauges for around $150. Worth it? I think so, answers half the questions when a car wont start!
Old Sep 14, 2005 | 11:11 PM
Spenser309's Avatar
where for $150? that actually sounds reasonable vs $250.
Old Sep 14, 2005 | 11:19 PM
CAT3's Avatar
Restricted User
I believe Stewart Warner gauges, and let me get some links going here....
or this from Dyno Tune Performance...
http://www.dynotunenitrous.com/store...p?idproduct=19
Old Sep 14, 2005 | 11:33 PM
Spenser309's Avatar
that was $175? could i use this http://www.tbyrne.com/ls1catalog.html in the guages section only $100 bucks for the sender and the guage.
Old Sep 15, 2005 | 05:18 AM
XTrooper's Avatar
I'm not crazy about digital gauges, but yes, that gauge and sending unit for ~$105 should work.
Old Sep 15, 2005 | 08:29 PM
Spenser309's Avatar
okthanks
Old Sep 16, 2005 | 12:40 AM
cyipher's Avatar
You can use a mech gauge but its very advisible to use an isolator kit
Old Sep 16, 2005 | 11:56 AM
DynotuneN2O's Avatar
LS1TECH Sponsor
Only issue with the mechanical gauges with the cheaper sending units is that they are typically off by 0-15psi at higher fuel pressures. If your just looking to see if you have fuel pressure they work fine. If your running a dry nitrous kit and looking for fuel pressure to rise, its nice to have repeatablity.
Cheers
Dan
