why use a stand alone fuel??
Because FUEL is dedicated to the Nitrous system alone, running lean on nitrous is one of the worst things you can do to a motor, things have a tendency to get really hot. A dedicated fuel system also allows the stock fuel system to provide engine fuel only thus hopefully decreasing any chances of low fuel pressure.
another ? if i were to do this sence i can control pressure couldnt i just turn up or down the fuel pressure instead of changing jets? is there a level sensor? how would u know if ur low on fuel and run out
Closed ex-Sponsor Account
Sure turning the pressure up or down is alot finer adjustment then swapping jets.. Do not know if the tanks come with sensor from the pics I have seen I would say no, there is not one..
Ricky
Ricky
You have to open the fuel cell and check the fuel level manually.
