15lb bottle won't fill
Old 09-27-2005, 01:17 PM
99SSLS1's Avatar
Default 15lb bottle won't fill
All the shop can get in it is about 10-12 pds. Its a nos 15lb bootle. I tired room temp, then they had it in the freezer for 4 hrs, then I had it in the refridgerator took it out and put it on ice in a cooler. Still they couldn't get it to fill. It always takes forever for the nitrous to go in too. He said he was gonna rebuild his pump next week but he fills his 15lb bottle with no problems. Any ideas?
Old 09-27-2005, 01:19 PM
Restricted User
NOSjohn's Avatar
His pump is probably bad. Sure he fills his 15 lb. bottle but probably only gets about 10-12 lbs. like you.
Old 09-27-2005, 03:45 PM
gollum's Avatar
He may have to "freeze" the bottle before filling if outside temps are hot. Newer pumps do not require freezing the bottle before filling.
Old 09-27-2005, 03:48 PM
Restricted User
NOSjohn's Avatar
They already attempted that.
Old 09-27-2005, 04:06 PM
NitrousDirect's Avatar
He prob does need a new pump, and yes freezing does help not sure why you went from freezer to fridge though. Try getting it filled somewhere else, tell him we can sell him a new pump that works
Old 09-27-2005, 07:35 PM
Robert56's Avatar
Another trick for filling and much quicker than freezing, is to hold bottle upside down and open valve for a short bit. You will feel the bottle temp come down and then you can get the reat of your poundage in. I have two 15lbers that I have to do this to on hot days, it works.
Robert
Old 09-27-2005, 07:44 PM
Ping King's Avatar
is his bulk tank empty? hey you never know.
Old 09-28-2005, 05:36 AM
99SSLS1's Avatar
Been there 3 different times in a month. The owner also has nitrous on his car. I may try a different place next time. Thanks
Old 09-28-2005, 09:06 AM
NXJeremy's Avatar
Sounds like it's time to rebuild his pump. And checking the filler bottle is also something to think about.
Old 09-28-2005, 09:07 AM
Nitro Dave's Nitrous Outlet's Avatar
I would also check and see if his main bottle was getting low.If so it will sound like it is still pumping nitrous but its not.
Dave
