Adjustable Harland Sharp 1.7's
Old 10-04-2005, 08:03 AM
98WhiteDevil's Avatar
Default Adjustable Harland Sharp 1.7's
I found needle bearins in my oil pan, so I picked up a set of Adjustable Harland Sharp 1.7 rockers. Could somebody give me a step by step process of installing these and setting the lash. I'm unsure of how to do this since our cars have hydraulic lifters. I have a 98 Trans Am, the engine is pretty much stock except for an LS6 intake and PCV kit.
Old 10-04-2005, 09:41 AM
rons 00z's Avatar
i didnt think harlands were adjustable?
Old 10-04-2005, 09:56 AM
PREDATOR-Z's Avatar
Unless they have a new model, HS are non adjustable.
Just use TDC method and 22ft/lbs
Old 10-04-2005, 10:08 AM
Go to Speedinc.com that's where I bought mine from, HS has new adjustable 1.7 rockers.
Old 10-04-2005, 11:57 AM
PREDATOR-Z's Avatar
Not much experience with these around here. Perhaps someone can chime in.
Probably will have to grind your valvecovers for clearance and perhaps the head too.
98 perimeter heads are renown to have clearance issues with all aftermarket rockers.
If I were you, I would just send those back and get them to do the LS1/LS6 "upgrade on the stockers". much less headaches.
Old 10-04-2005, 12:33 PM
Gunnar@Patriot's Avatar
They do make 1.7 adjustable.If you need any help with them, give Randy JR. @ Harland Sharp a call at 440-238-3260, he is a great guy to deal with.
Old 10-04-2005, 12:40 PM
Bryan @ Speed Inc.'s Avatar
speedinc girl kelly is my woman
Old 10-04-2005, 12:42 PM
gunnar... why aren't you plugging the patriot shaft mounted adjustable rockers that fit under stock valve covers???
Old 10-04-2005, 12:47 PM
The Patriot shaft mounts will not fit under a stock cover.
