Heads came in yesterday, a few pics
Well, it took 5.5 weeks for them to come in, but I'm happy with the outcome so far (#s to come). Precision Porting stg 3, with thermal coating to cumbustion chambers & valves. PRC Gold dual valve spring kit. Here are a few pictures.
The rest of my setup is: LGM G5X3 114, LS6 intake, LS6 oil pump, Double roller, 160* stat, Trick Flow hardened pushrods, 36# injectors....
Originally Posted by Snafu
about time!
mine should be done this weekend
NOSjohn, I wish it was a FAST, but the box has a LS6 intake in it. I bought it used, so thats what I picked it up in.
Ok guys, flow #s are as follows:
Lift Intake Exhaust
0.1000 87.5 67.2
0.2000 158.7 108.2
0.3000 230.5 162.0
0.4000 264.5 193.4
0.5000 289.3 217.8
0.5500 300.5 224.9
0.6000 299.2 232.7
0.6500 297.1 234.5
Lift Intake Exhaust
0.1000 87.5 67.2
0.2000 158.7 108.2
0.3000 230.5 162.0
0.4000 264.5 193.4
0.5000 289.3 217.8
0.5500 300.5 224.9
0.6000 299.2 232.7
0.6500 297.1 234.5
Originally Posted by oange ss
not too shabby for a sloppy weld job
Originally Posted by TSDuke
Yeah, it is about time, but hopefully worth the wait. Can't wait to hear your results. I wish you were closer to me, I want to get these things on NOW!!
I can't remember are those 241 (LS1) or 243 (LS6) heads? The flow numbers look like LS1. Yours are slightly better than mine but not by too much...happen to know your runner size?
Have car will travel...you're not too far. Let me know when you plan on doing it and I'll see if I'm available. The tear-down is pretty simple but requires some grunt work and cleaning out the block which is time consuming (and very important). I'm guessing you're going with stock gaskets so you don't really have to measure PTD height to set quench, and if that's the case your PTV clearance should be fine...so mostly you'll just be bolting everything back up without too much complication. Anyway, let me know.
I know the feeling trust me! I clayed the cylinder tonight and checked PTV...my best measurements put me over .100" so it looks like I got the greenlight to finish this baby up. I'll be working on it evenings this week and should have it ready to fire up this weekend...hopefully I'll be able to get over to CAM for a tune on Monday.
Maybe next weekend?
Originally Posted by Brian Tooley
It looks like the "mixture motion dam" or "swirl dam" has been removed, that makes the port VERY close to the water jacket, was that area welded? If not were they pressue checked? Just curious.
I'm going to cantact them today to find out for sure. Thanks for the heads up.
-Tucker
