? about LS2 timing chain
is the LS2 timing chain any different from the LS1? im almost 100% sure it is, but the reason im asking is because when i went to the parts departmetn to order one, they said that the chains are the same..... does anyone have an exact part # for the correct one?
12586482
Absolutely NOT the same physically, probably the same part number (now) in GM's inventory.. Bottom line is, the LS2 chain has thicker end-plates, it's a beefier chain compared to what you have in the car now.. Do it. Order it w/ the LS2 part number if you have to.
Originally Posted by Katech
Yes, it's the same.
12586482
12586482
not the same physical chain at all. much beefier and stronger. wouldn't put another ls1 chain in my motor if i had the choice of putting the ls2 chain in instead.
i was planning on getting the ls2 chain to... now does that come with the gears? or do you use teh stock ones or what..... and what are those part numbers and how much should cost?
will it work with f13 and dual spring setup?
Originally Posted by CASHss99
so there nothing wrong with using the old chain gears? i mean if the ls2 chain is bigger and beefier wouldnt u need the gear to fit it?
nice kuz i have 63k miles so im just making sure,, i hope the f13 and dual sprigs give me alota power
I can't believe the those stock springs, oil pump, and chain can still take !
