Adding PE = No Effect
Old 10-14-2005, 10:14 AM
Ed Blown Vert's Avatar
Default Adding PE = No Effect
Was on the dyno checking AFR. At 4000 it was 12:1 so added 5% to the PE table @ 4000. No change in AFR. Then added another 10% then 15%. Still no change. Everywhere else I had no problem changing the AFR.
What am I missing?
Old 10-14-2005, 10:19 AM
oange ss's Avatar
adding to would make it richer
Old 10-14-2005, 10:21 AM
12secSS's Avatar
Ed,
What are you PE enable setting (MAP, TPS%, RPM delay)? Was this a WOT dyno pass and what kind of dyno?
Old 10-14-2005, 10:26 AM
TPS is 26%, RPM delay is default (and I understand it has no effect). MAP is also default. It must be going into PE, otherwise why would go to 12:1?? Didn't have the problem on the last engine.
WOT pass on a Dyno Dynamics and DynoJet
And yes I do want it richer.
Old 10-14-2005, 10:28 AM
7 Second Club
NicD's Avatar
What injectors are you running and how much power are you making?
Mototron 60#
Numbers in sig
Old 10-14-2005, 10:29 AM
oange ss's Avatar
maybe check OLFA tables
Old 10-14-2005, 10:32 AM
7 Second Club
NicD's Avatar
What about fuel pressure? vac/boost referenced regulator? Did you log the inj duty cycle?
Never seen this problem before unless the injectors are maxed, but it really doesn't sound like they would be on your setup.
Old 10-14-2005, 10:36 AM
Billiumss's Avatar
Add some fuel via the VE table..........
Old 10-14-2005, 10:38 AM
FP started @ 60# and dropped to 50# (Ractronix FP). Injector DC was if I remember correctly 75% @ 6500. No referenced regulator
I know they are not maxed out, didn't have a problem dropping the AFR @ 6300 from 12:1 to 11:1
Old 10-14-2005, 10:41 AM
LS1TECH Sponsor
foff667's Avatar
why not logged commanded afr to see if its at least attempting to go richer
Old 10-14-2005, 10:42 AM
Kleeborp the Moderator™
MeentSS02's Avatar
What is your enrichment rate set at? That has a big impact as to how quickly it ramps into the extra fuel...max rate is 4.0 (where mine is).
Old 10-14-2005, 10:43 AM
Next time I am on the dyno, I'll check commaned. I didn't touch enrichment rate.
Old 10-14-2005, 10:47 AM
HumpinSS's Avatar
what were your iat's
Old 10-14-2005, 10:49 AM
I'll have to check the EFI log, but I think around 100
Old 10-14-2005, 10:53 AM
JMBLOWNWS6's Avatar
This is why I told ya to get a better fuel setup. Or at least a FPR with return at the rails.
HumpinSS's Avatar
Celsius or fahrenheit
Old 10-14-2005, 10:54 AM
TAQuickness's Avatar
I don't have my software with me to check, but for some reason I *think* I recall seeing a parameter that limits max enrichment. I could be talking out of my *** too.
Old 10-14-2005, 10:55 AM
I only have this issue @ 4000 rpms. Everywhere else I can change the AFR.
Originally Posted by HumpinSS
Celsius or Fahrenheit
Fahrenheit
