Northwest Members WA, OR, ID, MT, WY, SD, ND
rear ends???
Old 10-15-2005, 02:51 PM
Lunchbox01's Avatar
Location: Stationed at NAS Whidbey Island in Northwest WA.
Default rear ends???
Im sad, It has finally set in that I cant make both tires spin together when I smoke them. I was sure that a trans am could do it stock. I wish there was somthing I could do that is not too expensive. :sad: please help and I will you forever.
P.S. stop at me
Old 10-15-2005, 02:52 PM
teh PuRpL3z
DrEvyl's Avatar
Trans Ams have a posi differential stock. If you car can't do it, your carrier is probably fried. There are a number of options in replacing it...
One would be to just replace the stock one... but personally I'd recommend using an Auburn or a Eaton carrier to replace it.
Old 10-15-2005, 02:55 PM
Rottluver's Avatar
..........................12 bolt w/posi........................
Old 10-15-2005, 09:49 PM
WAHUSKER's Avatar
If the rear end is not broken & working poreprly, both tires should spin.
Old 10-15-2005, 10:17 PM
sardog46's Avatar
I had that problem with the stock rear end, It means the posi unit is toast. If you have the money I would go with a 12bolt or 9 inch, but if not mybee look into the difrent types of posi's that have already been talked about.
Old 10-16-2005, 01:48 AM
Lunchbox01's Avatar
How much would a carrier cost? Where could I get one?
Old 10-16-2005, 02:22 AM
Tranzor's Avatar
Not necessarily... I tore up the posi in my 12 bolt and looking at the video from that day at the track, both tires were spinning just fine... but the rear end was definitely screwed. It just had trouble unlocking...
But if only one tire is spinning, that is definitely something wrong and needs to be fixed.
Old 10-16-2005, 04:14 AM
Lunchbox01's Avatar
whats the cheapest proper way to fix it. I just dont have the money for a new rear end, or 12 bolt or whatever. Im not too car smart bit with help I can be .
Quick Reply: rear ends???
