possessed car. Something Shorting?
Ok, this is weird. If my car goes above 2500 rpm's my glovebox light goes on. Also if I go above 2500 or so rpm's and let off, I can FAINTLY hear my horn chirp. When my transmission gets hot, and I'm driving around for a bit, my battery doesn't want to hold a charge. I can see my voltmeter dipping WAY into the red. I usually only have these problems when AC is on. If AC is off, everything is fine. I'm so lost. What can I look into, and is this something that will cost me a lot of money if I have a mechanic diagnose?
jeez, have u replaced ur radio lately? sounds like the AC is probably goign out on you and grouding itself out............ Or u have something seriously wrong with your electrical system.
Already swapped battery AND alternator. I also drove last night, turned AC off, and it seems like the glovebox light turning on is more load based than rpm based. It just doesn't make sense. This seems to have started after I swapped from an A4 to an M6. I did the swap myself, but the wiring is all done right.
The horn chirp is probably related to the alarm system. It's not aftermarket also, is it?
Ungrounded Moderator
It would seem that the glovebox light problem is unrelated to the other electrical gremlins. The glovebox light is a very simple circuit with power coming from the BCM (this is so it can shut off power 10 minutes after the car is shut off to prevent accidental draining of the battery), going through the switch/lamp directly to ground. If the light is going on under any circumstances other than opening the glovebox door then the switch/lamp assembly must be loose, misadjusted, or faulty.
