View Poll Results: what should I do to my 98 SI motor
just add the LSX intake to the 98
9
75.00%
install 02 fbody cam/heads
3
25.00%
just install 02 fbody cam only
0
0%
Voters: 12. You may not vote on this poll
98 motor with 52 k miles ?
Old 10-19-2005, 12:52 PM
11SECSS's Avatar
Default 98 motor with 52 k miles ?
I have a 98 motor for my 00 SS and was going to stay SI's but was wondering if it would be worth changing to 02 cam and heads or just stay with the 98 cam heads...this motor only has 52k miles.
Old 10-19-2005, 02:27 PM
98Z28MASS's Avatar
I believe that the 02 heads are better, but the 98 cam is more agressive. Either way if your going to have to pay for either of these id say get an aftermarket cam because changing the heads and cam is gonna do nothing for you HP wise. Id say if your going to change the internals at least put in a bigger cam and some better heads. As for the LSX intake id say go with an ls6 for now as it will give you good gains and you dont need the lsx yet for your application. If you go with a big cam and heads down the road then the LSX is the way to go. What are your goals for your car BTW (HP/TQ numbers etc...)
Old 10-20-2005, 09:42 AM
11SECSS's Avatar
I want to go 11's on SI again this time with a 98 motor looking for 340 rwhp with all the bolt ons
Old 10-20-2005, 09:58 AM
98Z28MASS's Avatar
Id say then keep the 98 cam as i believe it is more aggressive and get an ls6 and the newer style heads.
Old 10-20-2005, 10:00 AM
98Z28MASS's Avatar
and im guessing your gonna be spraying? Or some type of FI?
Old 10-20-2005, 11:21 AM
Torqued's Avatar
What's you goal for the '98? None of your options are cost effective unless the parts and labor are free. And even if everything is free is it worth the effort for 5-15rwhp? At a minimum I'd put in a basic TR 224 cam kit.
Old 10-20-2005, 11:36 AM
SAM98WS6's Avatar
forget the 02 stuff...
Old 10-20-2005, 01:11 PM
JoeyAnderson's Avatar
If you're set against an aftermarket heads/cam setup, this is the way to go:
Old 10-20-2005, 01:44 PM
11SECSS's Avatar
no power adders just N/A I went 11.45 with my 01 SS before it got totaled now I bought a 00 roller and going to put a 52k mile bone stock 98 motor and try for 11's again I think it can be done I dont want to open the motor up that way I can say it has OEM SI not anything else.
Old 10-20-2005, 01:46 PM
98Z28MASS's Avatar
So wait that was 11's on a bone stock internal engine? Like cam, heads, everything and no power adder? Was that in a gutted car with all bolt ons and DR's?
Old 10-20-2005, 02:50 PM
11SECSS's Avatar
nope 11.72 @3437 pounds with driver to meet NMCA rules 11.45 was on a diet weighing about 3300 with driver but 11's are easy even at full weight just do a search.
Old 10-20-2005, 02:58 PM
98Z28MASS's Avatar
Oh im not disagreeing I just have never heard of a stock engine car with bolt ons (probably making 330-340 rwhp) at full weight with no aftermarket cam or heads or any power adders running an 11 second pass thats all. Best my buddy has mustered with a TR 224 and stage II 5.3 heads (pushing around 410 rwhp) was low 12 second pass and hes running DR's.
Old 10-20-2005, 02:59 PM
Keenov's Avatar
11's is not impossible for a stock internal LS1.
If he is still in the 12's, he needs to sell his car or let someone else drive it. My '98, with just the tr224, ran 12.3 with a 1.9 60' with all bolt-ons. 367rwhp And he has some decent heads, he should be low 11's.
Old 10-20-2005, 03:34 PM
11SECSS's Avatar
heres a list of 50 people with stock internals running 11.83 or quicker and some of them are 3500 pounds which is most likely full weight
Magnus ------ 10.987 @ 119.31 (1.42), 97 Firebird A4, YPT4400, 4.10, 2920, 12/04
Hawkn01 ----- 11.256 @ 118.48 (1.52), 01 Firehawk A4, TCS4200, 3.73, 3086, 03/04
RUQWIKR ----- 11.273 @ 120.02 (1.46), 01 Formula A4, YTP4400, 4.11, 3140, 04/02
Skelton ----- 11.301 @ 119.29 (1.50), 01 Formula A4, YTP4400, 4.10, 3130, 03/05
SilentbutViolent 11.302 @ 117.84 (1.52), 98 Camaro Z28 A4, YTP4600, 3.73, 3128, 11/04
V6 Bird ------ 11.322 @ 118.67 (1.53), 01 Formula A4, YTP4000, 3.23, 3170, 11/02
BAIN ------- 11.429 @ 116.81 (1.51), 00 Camaro SS A4, TCI4400, 3.73, 3400, 12/04
Lane --------- 11.458 @ 117.33 (1.53), 01 Camaro Z28 A4, YTP4200, 3.42, 3350, 11/02
11SECSS ----- 11.458 @ 116.94 (1.50), 01 Camaro SS A4, YTP4000, 3.23, 3200, 04/02
DMcRacer ---- 11.468 @ 116.88 (1.56), 02 Camaro SS A4, PY3800E, 3:42, 3400, 11/03
MDBlackZ28 ----- 11.494 @ 115.85 (1.56), 00 Camaro Z28 A4, TCI4000, 4.10, 3150, 07/05
Black Sunshine 11.496 @ 116.24 (1.52), 01 Camaro SS A4, Vig3200, 3.73, 3225, 10/01
Birdman ------ 11.519 @ 115.60 (1.55), 98 TransAmWS6 A4, YTP4400, 3.73, 3180, 05/02
WILWAXU ---- 11.544 @ 115.36 (1.53), 01 Formula A4, YTP4200, 3.73, 3320, 01/04
01-Z -------- 11.549 @ 117.82 (1.60), 01 Camaro Z28 M6, Mcleod, 4.30, 3090, 09/02
Lynda ------- 11.550 @ 115.36 (1.51), 01 Camaro Z28 A4, YPT4400, 3.42, 3340, 12/03
Raughammer - 11.562 @ 115.25 (1.50), 98 Camaro Z28 A4, YTP4500, 3.73, 3175, 01/01
2002Z ------- 11.564 @ 115.75 (1.52), 02 Camaro Z28 A4, YST3500, 3.73, 3450, 10/02
Colonel ------ 11.565 @ 115.54 (1.51), 00 Camaro Z28 A4, YTP4600, 3.89, 3285, 10/00
RAGEman ----- 11.568 @ 121.13 (1.71), 01 Camaro Z28 M6, stock, 3.42, 3200, 03/02
Dangerous SS - 11.576 @ 116.52 (1.55), 02 Camaro SS A4, YTP4400, 3.23, 3360, 01/04
MikeHoffpauir 11.593 @ 116.00 (1.56), 00 Camaro Z28 A4, YTP4400, 3.42, 3340, 12/01
JFM ---------- 11.623 @ 115.44 (1.57), 99 Camaro SS A4, YTP4400, 3.42, 3350, 01/02
mmiller ------ 11.664 @ 114.55 (1.53), 01 Camaro SS A4, YST3500, 3.23, 3312, 02/02
JS12 -------- 11.672 @ 119.23 (1.72), 02 Camaro Z28 M6, Spec S4, 3.73, 3435, 11/02
LARRY01Z28 -- 11.674 @ 118.20 (1.71), 01 Camaro Z28 M6, Star, 3.73, 3265, 10/02
JASON ------- 11.682 @ 116.37 (1.62), 98 Camaro Z28 A4, YSY3500, 3.42, 3340, 01/03
FASTR A4 ---- 11.694 @ 114.57 (1.56), 00 Formula A4, YTP4400, 3.73, 3450, 04/03
2Quick4U ---- 11.721 @ 115.19 (1.58), 00 Trans-Am A4, Vig3200, 3.73, 3500, 10/01
MADCOW ------ 11.730 @ 115.80 (1.57), 98 Camaro Z28 A4, TCS4200, 3.73, 3300, 03/04
black02-z28 -- 11.731 @ 113.81 (1.50), 02 Camaro Z28 A4, YSS4200, 3.73, 3600, 12/04
z28kid98 ----- 11.740 @ 113.55 (1.56), 98 Camaro Z28 A4, YTP4400, 3.23, 3250, 10/02
Durien ------ 11.747 @ 117.59 (1.60), 99 Camaro SS M6, Cartek, 4.11, 3487, 02/04
Raptor99 --- 11.756 @ 115.06 (1.57), 99 Trans Am A4, TCI3800, 3.73, 3440, 11/04
Steve350 ---- 11.761 @ 114.46 (1.55), 01 Camaro Z28 A4, YST3500, 3.23, 3430, 01/02
PewterZ28 --- 11.762 @ 114.53 (1.60), 02 Camaro Z28 A4, YTP4400, 3.23, 3360, 04/03
jay_99z ----- 11.767 @ 113.66 (1.56), 99 Camaro Z28 A4, TCS4200, 3.73, 3400, 11/04
Jnorris ------ 11.773 @ 113.02 (1.59), 98 Camaro Z28 A4, YTP4000, 3.23, 3390, 11/02
Top Fuel ---- 11.794 @ 113.38 (1.53), 00 Camaro Z28 A4, YTP4000E, 3.73, 3335, 10/01
Hugger ------ 11.796 @ 113.83 (1.64), 99 Camaro Z28 A4, YST3700, 3.23, 3440, 01/03
Jason99T/A -- 11.801 @ 115.66 (1.69), 99 Trans-Am M6, Mcleod, 4.30, 3450, 12/01
Bob2of3 ----- 11.806 @ 113.80 (1.54), 00 Camaro Z28 A4, YTP4500, 3.42, 3350, 03/01
Edge Hawk --- 11.807 @ 114.32 (1.58), 01 Firehawk A4, FBC4000, 3.73, 3415, 11/04
OnyxLS1 ----- 11.818 @ 116.05 (1.63), 00 Camaro SS M6, Cartek, 4.10, 3325, 03/02
promod1955 --- 11.812 @ 112.86 (1.566) 02 camaro SS A4,YPT 4400, 3.90, 3345, 10/04
Steve350 ---- 11.832 @ 113.11 (1.55), 01 Camaro Z28 A4, YST3500, 3.23, 3580, 01/02
jc2000formula 11.822 @ 114.50 (1.65), 00 Formula A4, YST3500, 3.23, 3550, 10/03
Colonel ------ 11.826 @ 113.12 (1.61), 02 Camaro Z28 A4, TCI3500, 3.23, 3550, 01/03
Silver LS! --- 11.83? @ 115.23 (1.56), 99 Camaro Z28 A4, Vig3600, 4.10, 3490, ??/01
Bad Habit Bird 11.83? @ 115.38 (1.64), 01 Formula M6, stock, 4.10, 3550, 05/02
Old 10-20-2005, 03:56 PM
98Z28MASS's Avatar
Just using this one as an example because its just about full weight:
So your telling me that a stock 00 Camaro SS A4, stock cam, stock heads, no FI, and 3.73 gears at 3400 pounds can run those times? How is that possible? Again im no doubting you but Id just like more info about what is involved because those are insane times without any internal engine work done!
Old 10-20-2005, 04:00 PM
tripps's Avatar
yeah im puzzled as to how your gonna squeeze out an 11 second pass on NA, with no big power adders and close to full weight? you must be one hell of a driver
Old 10-20-2005, 04:04 PM
A4s are ET ******. I'm jealous.
Old 10-20-2005, 04:20 PM
Keenov's Avatar
Weather plays a roll in it. 60' plays a roll in it. Weight plays a roll in it. 3400lb's with a driver is not near full weight. Especially for an SS as it more than likely came with a lot of options. I could see it being full weight for a stripper Z + driver.
Old 10-20-2005, 04:26 PM
98Z28MASS's Avatar
I dunno about low 11's. He doesnt launch extremely hard as he is still on his stock 10 bolt and his clutch is slipping but his best run I believe was 12.09. The track conditions were pretty shitty and he hasnt gotten back with his new clutch yet so im sure he can break into the 11's. Hes a decent driver but nothing special, im sure someone with better track skills could muster a mid 11 pass. But thats still not the point I was trying to get at, and that is with his mods he was still low 12's/high 11's, and that is with a lot of internal engine mods. So how does a stock internal bolt on car run a 11 second pass?
Old 10-20-2005, 04:28 PM
98Z28MASS's Avatar
I mean a 12-bolt is not a bolt on either, so id love to see a stock ls1 m6 or a4 with a big stall and gears run an 11 second pass. Again not saying it is impossible but they must be cutting like 1 second flat 60' times, which is pretty much not happening.
