What power will the LS6 cam make me?
Bought an LS6 cam, springs and retainers included, from what I read I need to get some longer pushrods, anything else??My main question is how much rwhp will I gain off of this, and how much higher can I spin my motor with this cam..I also have a powerdyne(yes..flame on) going on, and it doesn't like high rpms from the research I have done also...but yea, any opinions...thanks guys
LS1 Tech Administrator
LS6 cam will give you some solid gains from 4000 rpm and up. Stock length 7.40" pushrods are fine for unmilled stock heads, but spend the extra money and get some chrome moly pushrods. The LS6 cam makes very little overlap so it's a good candidate for a blower.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Pushrods
Here are the correct pushrod lenghths depending on your setup.
LS6 cams have smaller base circle....pushrod lengths as follow...
If you are doing:
LS1 heads/valves + LS6 cam > 7.425 aftermarket
LS6 heads/valves + LS6 cam > stock or 7.40 aftermarket
LS6 heads/valves + Ls1 cam > 7.375 aftermarket
Thanks to PREDATOR-Z for this little chart
If you are doing:
I installed an 02 LS6 cam in my car when it had 4K miles on it.
Mods consisted of Lid, Ported TB, ASP, LS6 cam & valvesprings, JH Longtubes & ORY thru SLP DD muffler, Rapid Motorsports Dynotune 376rwhp @ 361rwtq - Stock 241 heads Used 02 LS6 valvesprings & retainers stock pushrods
Car sounded stock and drove like stock even untuned. The tune did add power and made the car feel better throughout the powerband. I liked the cam but was disappointed in the power from idle to 4500rpms. The setup did not hit 350rwtq until 4300rpms! My current setup hits 350rwtq at 3000rpms. It did pull pretty hard from 5Krpms to 6500rpms.
good deal, thanks, with the blower goin on about a week after the cam, im not really worried about the power so much as how high the rpms will go and the pushrod length, hopefully ill be netting somewhere around 450+ at the rear
i was in the same boat as you.
i was reeally looking for a cam that sounded like stock at idle, got good fuel economy and emission safe.
the ls6 was my top chioce. but as i started doing more and more research i realixed that there are other cams out there like the ls6, but yeild more power. the ls6 cam only comes alive around 4-4.5k rpm. so i started to look into some other cams. i chose the tsp 220 cam. it sounds great at idle.. barely noticeable and it just screams off the line. i got better fuel economy with this cam and i passed emmssions. now that i have installed headers. i can sorta hear the cam a bit more at idle.
if i were to do it again. i honestly would have went with a bigger cam. like a 224 on a 114. i thought i wanted a cam that was as sleeper as they get. but ****, i drive a camaro SS... this car is anyything but a sleeper! i want a cam that has a more noticebale idle. ive heard the 224 jus recently and it sounds real nice at idle. it doesnt lope too hard but its not non-existent either. and drivebality is great. this cam is a very popular cam among ls1 owners and it wont dissapoint.
my advice would be to research a bit more before you install it. look at teh cam you want and go one step bigger. cause you will always long for more power.
good luck!
good luck!
heres what my car sounds like with just a cam. (no headers):
http://www.ls1sounds.com/SLPloudmout...m_00SSamit.wmv
and hears it taking off. again cam only no headers:
http://www.ls1sounds.com/SLPloudmout...a_lid_amit.wmv
i havent got any clips yet with the headers.
that sounds really good, i have headers and ory, i really don't want the idle to change, im really going for the sound of no more than a bolt on car, and just have a lil bite to it when i go..another reason i am gettin the cam, is that i got a great deal on it, i am saving money b/c i have to buy some flex a lite fans before the blower can go in, thats all im lacking, thanks for you reply amit and the soundclips you provided
5.3 with ls6 cam
i have a truck with the ls6 cam should i go with something bigger.. so far i like it but i only hold it to 6000 could i have the the truck re tuned for something higher i just got a racing tranny too.
Originally Posted by amit
no problem,buddy.
i didnt know you got such a good deal on it. that changes everything! theres nothing like bang for the buck!
