Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
10 ton press good enough to change u-joints?
Old 10-24-2005, 10:29 PM
JustAnIlluzion's Avatar
Default 10 ton press good enough to change u joints?
like this one,
http://www.harborfreight.com/cpi/cta...emnumber=44811
Old 10-24-2005, 10:47 PM
2K2WS6TA's Avatar
I'd think so, I just use a bench vise
Old 10-24-2005, 11:09 PM
code4's Avatar
It's way overkill, it takes very little pressure to remove/install u-joints. Like said above I also use a small vice to replace u-joints.
Old 10-25-2005, 12:14 AM
Carter Hays's Avatar
No, like was said above you don't need it for u-joints. But once you have a press you will wonder how you got along without one, so buy one anyway
Old 10-28-2005, 12:19 PM
KyleSx5's Avatar
Just a small bench vice will work for sure and its real simple to do.
Old 10-28-2005, 12:56 PM
awesome guys, i need to buy a vice anyways .
Old 10-31-2005, 08:44 AM
robertbartsch's Avatar
There are better designs available at HF which can be used for rear end work. I use a home vice for u-joints too.
Old 11-01-2005, 07:58 AM
Moderator
jimmyblue's Avatar
A C-clamp and a socket just big enough for the end
cup to slide into, is the only thing I've ever used.
Old 11-01-2005, 09:24 PM
69chevy's Avatar
Not a bad idea. I would've never thought of that.
Old 11-02-2005, 12:11 PM
Maggie's Avatar
"""10 ton press good enough to change u joints? "
Yea, be carefull and dont make a pancake out of it!
Old 11-05-2005, 06:50 AM
speedracerz's Avatar
harbor frieght also has a ten ton a frame for less money than that. it was on sale last week for a lil more than $100
Quick Reply: 10 ton press good enough to change u-joints?
