Finally got it running and boosted!!
https://ls1tech.com/forums/dynamometer-results-comparisons/410909-408-w-et-225s-f1-procharger-dyno.html
Here is my post with the dyno information.
Thanks guys..
I am using a Nasty Performance race tank with a Weldon fuel pump. I think I need a little more pump though, the fuel was dropping off at about 5500.
Yes, I am still using the stock PCM.
Originally Posted by onfire
A Weldon 600A won't support that kind of power if your are boost referenced.
Yeah, I found that out. Nate assured me that it would be enough and he had others running it with 900+ HP. I guess he was wrong. I have it working right now, Allan adjusted the injectors to compensate. I guess its a good thing I insisted on the 75lb injectors over the 60s.
