How to break shit.. [pics]
Old 11-19-2005, 10:10 AM
blacktransam's Avatar
Default How to break ****.. [pics]
i figure if you gunna break it do it right..
1) build LS1 with heads cam..
2) jet nitrous kit at 200
3) throw some slicks on and get them good and sticky..
4) launch at 4k and spray it out of the hole..
end result
Old 11-19-2005, 10:23 AM
Turo's Avatar
Holy crap, is that an axle (or should I say was)? What spline?
Old 11-19-2005, 10:34 AM
stocker.. yea it was.. which is weird cause the last 2 10 bolts i broke the spider gears shattered this time.. axle snap..
Old 11-19-2005, 11:18 AM
00tals1's Avatar
Your car must be trailered
Old 11-19-2005, 12:37 PM
flyinZ's Avatar
holy $hit!! lol, i like that.
Old 11-19-2005, 05:18 PM
yes it was trailored to the track that night..but usually no its a street car.. and its staying that way
Old 11-19-2005, 06:15 PM
jj_z28's Avatar
kinda looks like my axle after the 1st launch from 3500 rpm. This was on nitto's at 19 psi w/ a stock 10 bolt.
Old 11-19-2005, 06:46 PM
Moderator
davered00ss's Avatar
How's the rest of the car?
Old 11-20-2005, 10:13 AM
rest of the car is fine.. how would it get messed up.. the car only moved about 3 feet
Old 11-20-2005, 12:06 PM
ULTIMATEORANGESS's Avatar
that sucks.
Old 11-20-2005, 08:56 PM
Krab's Avatar
Ha, that sucks. I know how it feels to get those tires nice and hot, see the green light turn on, let out the clutch and BAM, something gives. Not a good feeling, but it could be worse. Seems like you're making some power and getting some good traction.
Old 11-20-2005, 09:08 PM
smoknta's Avatar
Your lucky it did not come out and damage the wheel well.
Old 11-21-2005, 12:47 PM
RDTA's Avatar
that sucks man but time for a 9''.
Old 11-21-2005, 02:37 PM
ehh i'm goin spooled 12 bolt
Old 11-21-2005, 04:20 PM
2QuickZ's's Avatar
The brake calipers keep the axle from coming out on a rear disc brake setup like ours.
My carnage was from a 5K dump on E/T drag radials. The 4.10 gear survived with out so much as a scratch but I sheared the axle like you and also cracked the dif.
Old 11-22-2005, 05:46 PM
Zymosis's Avatar
Glad others can break stuff for my viewing pleasure. (Knock on wood)
Old 11-22-2005, 05:56 PM
chaman's Avatar
Old 11-22-2005, 09:04 PM
CuNfUzEd's Avatar
YIKKKKKEEEESSSSSS!!! My car is putting down 6xx HP.I have a t56 and stock rear. Gulp! Looks like I'll have to keep radials on until I can afford to **** something up. Would nitto's be to much? What rpm would you launch@
Old 11-23-2005, 10:31 AM
Zymosis's Avatar
Keep radials on, you're just asking to break it if you hook up at all with that much HP
Old 11-23-2005, 10:46 AM
QUASAR's Avatar
That looks all to familliar...
When built right, the gearset is hardly ever a problem. It's always the junk diff or junk axles that take a dump. To the guy who started this thread, lol, you dont need h/c and 200 shot to do that, all you need is some drag radials and boltons N/A Oh and take a good look at your differential and make sure it isnt cracked like in the pic 2QuickZ's posted, they usually do crack near where the axle breaks.
