Gears & Axles - Cost to rebuild stock 10 bolt
Phoenix 5.7
11-23-2005, 05:08 PM
i got a bad axle bearing on the passenger side of my T/A. since i need to get it changed, i figure i better go ahead and change all the bearings, seals, and anything else needed. I will also be gettin a better diff cover. what is the cost for the parts, and what would the typical labor cost be? id like to do it myself, but IDK if i can. also, if my axle is shot cause of the bad bearing, what axles should i upgrade to, or should i stay with stock?
macknmikey
11-23-2005, 07:33 PM
go with a 12 bolt if you got cash to splurge
black01_WS6
11-23-2005, 07:48 PM
save your money and get a 12 bolt, but if you want to keep the 10 bolt, you can get moser axles and diff cover. as for rebuilding the stock 10 bolt you could spend about 400-500. thats why I would reccomend the 12 bolt.
ULTIMATEORANGESS
11-23-2005, 08:08 PM
itll break again trust me.
yes theres claims of 10 bolts holding up under alot of power but theres alot more breaking with stockish power.
Phoenix 5.7
11-24-2005, 03:10 AM
its not a matter of it holding up. i have to get it fixed soon, this mf is howling like crazy(passenger wheel bearing). i just want to fix it up good enough to last me till i can come close to affording a 12 bolt.
blue01ta
11-27-2005, 10:18 PM
You should be fine with the factory 10 bolt beings it's an automatic. I don't know what it would cost exactly to have it rebuilt but you can buy good used ones for around $300 so I wouldn't pay anymore than that for it.
ssheets
11-27-2005, 10:32 PM
From LS1speed.com
itemno description price buy
MOT75IK Master Install Kit $99.99 buy
MOT75CS Crush Collar $6.00 buy
MOT75CG 10 bolt Rear Cover Gasket $6.00 buy
ninobrn99
11-27-2005, 10:48 PM
sometimes not everyone can afford to get a 12 bolt or 9". Sometimes your gonna have to put money into something to get you by till you can afford something else...im in that boat...for now ;)
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
