turbo collector, whats the best way?
Guest
Posts: n/a
OK, Im having some problems making a turbo collector that fits right. Im using 1.75" 304ss piping and trying to fit it to a 3" v band. whats the best way to try and make it? Ive never made headers before, let alone a collector. I can weld but dont know where to start.
so far i have 4 peices of 1.75" that have 3 inch legs and a 20 degree bend in it, am i going the right way?
here is a pic of the my first header tacked up
any help would be awesome
Dan
Dan
LS1Tech Sponsor
Two ways I do it. Depending on weather its a budget lower hp setup or a all out set up. something like a burns 4 into one merge (slip on) or I use custom ones from SPD. Then go to a 3" v-band flange or into a t4 or 6 flange. Or the cheaper rout would be to go with a formed 4 into one collestor. A little more work as you have to make a piece to fill in the gap between the four pies and just weld around the four when done. Then go to a v-band or t-4 flange. You can get the round to t4 or t6 transitions from SPD also.
Guest
Posts: n/a
id rather not buy a peice though, im trying to challange myself ( probably end up buying a peice and spending twice the money, just like usual , lol)
its for the truck in sig. GT-40,88mm turbo ball bearing on my 370ci motor. guess ill keep plugging away at it
so far i have 4 peices of 1.75" that have 3 inch legs and a 20 degree bend in it, am i going the right way? any help would be awesome
Dan
Dan
Use tubing that has a slight bend in em, maybe 45 degs?? Looks like the burns collectors have a slight bend in the tubing so all the pipes end up straight. More pics here to reference..to give you some more ideas?
http://www.burnsstainless.com/MergeC...ollectors.html
Awesome looking headers btw..
Guest
Posts: n/a
Those look like the 20 degree bends that I have. I just dont want to break down and pay that much for a collector, especially since i need 2.
Thanks on the header, its my first attempt at it and dont think i did too bad. Ill keep you guys updated. The turbo should be here this week so ill be working on it all weekend long
