how many turbo lt1 cars and setups on here?
I am sort of new to high powered turbo setups for the lt1 and I am trying to get a few others with know how about turbo lt1s together in here.
list if it is a kit or custom, pics are plus installed or just the setup
make & size of turbo
psi
heads & cam (if it's not top secret)
compression ratio
and if known, hp, tq, et and trap
and any thing else that you fill like sharing about your set up
I will start
custom single turbo
monster stone t70
6 psi
stock heads and cam
cr stock 10.5:1
?hp, ?tq, 12.7 @ 107
blown head gasket, rebuilding and hope to soon be done with,
custom single turbo
monster stone t70, for now, looking at mabey going master power t3 t70
15 psi
stock possably p&p cam is 234/242 .575/.595 112lsa (gm847) I know so many think it's the wrong cam for turbo. we will see.
cr 9.25:1
looking for 600rwhp & 600fptq +/- 12.0 @ 120+ stock 10 bolt for now 3.23 gears
my car is a 93 with stock 3.23 10 bolt, and m6 upgraded clutch. I have no pics of my set up right now, at least not on line.
psi
compression ratio
I will start
custom single turbo
monster stone t70
6 psi
stock heads and cam
cr stock 10.5:1
custom single turbo
15 psi
cr 9.25:1
i just decided to part out my turbo car.
it was a custom kit
pt88 intercooled
motor was a 400ci lt1 solid roller
afr 215RR heads with victor jr intake
custom built t56 followed by a 9 inch
it was a custom kit
pt88 intercooled
I just started my turbo build up, I got all my major parts ..
Precision 76mm GT42 turbo
twin Tial 38mm waste gates
Tial 50mm BOV
HKS boost controller
Precision intercooler air to air converted to water to air
I'v got all the pipe to build the engine to turbo stuff.
sorry I do not have any pics I'v just got started good luck with your build.
Tial 50mm BOV
