f14\15 vs g5x4 vs ms3 vs trex
Old 12-02-2005, 05:24 AM
Jpr5690's Avatar
Default f14\15 vs g5x4 vs ms3 vs trex
i have a stock bottom end, boltons, 3.73 gears 3500 stall.. which of these cams would give me the most power\accelration with a set of afr 205 heads....
also for any\all of these cams would afr 205's be the ideal head?
also im looking for a real nasty idle.. this car gets driven for fun only (mostly street raceing)
Old 12-02-2005, 07:27 AM
yak
yak's Avatar
get ready for flycutting. I'm pretty sure none of those cams will clear with afr 205s. I run an X3 on a 112 and it is close in terms of PTV. Most of those cams will make a lot of power up top. Are you ready to spin to 7k? it can be done on a stock bottom end. My limiter is set at 6900 and I have a stock bottom. you will want a bigger stall. something in the 4000-4200 rqange.
Old 12-02-2005, 07:36 AM
s346k's Avatar
with that stall, no bigger than the f-14. any of the other cams...4400 stall
Old 12-02-2005, 08:59 AM
FormulaFire's Avatar
I vote G5X3.. Not as big but you'll get results..
Old 12-02-2005, 12:34 PM
Josh's Avatar
The AFRs actually have more PtV clearance than stock heads, so any of those cams should fit without having to flycut.
Josh
Old 12-02-2005, 12:59 PM
dug
dug's Avatar
The torquer rev 2 cam from TSP looks interesting. I think its 232 234 112 +2 on x-er lobes.
Old 12-02-2005, 01:03 PM
Bryan @ Speed Inc.'s Avatar
Josh
is this true????
Old 12-02-2005, 01:20 PM
LS1Tech Premium Sponsor
Brian @ Texas Speed & Performance's Avatar
If the AFR 205s are unmilled they will clear with the MS3.
Brian
__________________
01 NBM Z28- A4 w/3.23s, TSP Black Lid, Hooker Catback, Pacesetter Headers w/ORY, ASP Pulley, Ported Throttle Body, TSP Torq. v3(231/234) Camshaft, TCI 4400, PRC Stg 1 Heads
www.texas-speed.com
(806) 866-0734
Old 12-02-2005, 01:24 PM
yea but what about actually having MORE p to v clearance than stock heads? i want to know if that is true.
would a t-rex fit w/ the AFR 205s?
Old 12-02-2005, 02:03 PM
Jpr5690's Avatar
ok im thinkin the 5.3L tsp PRC 2.5 heads with a tsp 233\239 cam what you all think?
Old 12-02-2005, 02:14 PM
i think it'll make some sick power.
Old 12-02-2005, 02:25 PM
Jpr5690's Avatar
ok what about that compared to afr 205 heads and a g5x3 cam?
and what about the same afr 205 heads and a fm14 cam
Old 12-02-2005, 02:28 PM
i don't know how the PRC heads perform relative to AFR heads.... AFR's are proven performers. as far as the cams... i don't know the specs on the G5X3 or the FM14.
someone fill me in?
Old 12-02-2005, 02:30 PM
Jpr5690's Avatar
or to consolidate my thoughts im down to 3 ideas...
1: PRC 5.3L STAGE 2.5 HEADS WITH TSP 233\239 CAM $2400
2: FM 14 CAM AFR 205 HEADS $3200
3: G5X3 CAM AFR 205 HEADS $3100 (FLYCUTTING REQUIRED)
Old 12-02-2005, 02:32 PM
are you sure you have to flycut with the G5x3? juggernaut used the G5X4 with AFR 205's and he said his pistons are not cut.
Old 12-02-2005, 02:34 PM
Jpr5690's Avatar
What I Like About The Tsp Package Is It Is Economical And Makes Ok Power From What Ive Heard
What I Like About The Fms Package Is I Percieve It To Be The Most Popular
What I Like About The Lg Package Is They Claim Ill Be Shifting At 6600 Rpms And That This Cam Is Capible Of 480rwhp (on A M6)
Old 12-02-2005, 02:37 PM
me - i'm all about drag racing, and max power... i'd do the LG cam w/ the AFR 205's. that's just me.
Old 12-02-2005, 02:41 PM
Jpr5690's Avatar
i just spoke with bobby @ lg he said they mill their afr heads so they do need flycutting .. on out of the box afr 205's i dont think its nessary
LS1 BU's Avatar
With that stall I think an F14 at the most. I would personally run a f11-f13.
Old 12-02-2005, 02:42 PM
Jpr5690's Avatar
lg is tellin me im good to go with 3500 stall??
Quick Reply: f14\15 vs g5x4 vs ms3 vs trex
