ms3 vs. t-rex
ms3 vs. t-rex
hey guys, i need some info, right now im running the ms3 cam in my 00 z28,stock heads, m6 4.33 gear with 9 inch rear, and i have 150 shot nx, i do not daily drive this car, it sees maybe 1,000 miles year, and the track 5-7 times, do you think that the t-rex cam will make more power than my ms 3 cam is? and is it worth the trouble to change? 390hp/370tq through et streets na, 548hp/650tq nx, same tires
thanks,
paul
thanks,
paul
the t-rex should get you there, a buddy of mine switched his 235/240 for a t-rex and got something like 20 or 25rwhp out of it. Plus it sounds wicked! I think its a good cam to go with in your situation.
you might even want to just leave the MS3 in if you're running N20. The MS3 is supposed to be one of, if not the best "nitrous" cams out there. The t-rex likes N20 as well, but I don't think as much as the MS3.
The power difference probably isn't worth the money/effort. I think you'd be better off leaving the MS3 in and using the time/money for another upgrade.
