Powerdyne missing Parts?????!?!!!
So, I bought a powerdyne kit from a member on the forums. He claimed everything was there and even included a pulley. The pulley doesn't fit and is so big it would barely make 4 psi if i was even able to put it on. I also looked through the install instructions and I guess I need to remove the stock fans and put aftermarket ones in? Is this true? Because what I bought from the member didn't have fans! Help me out. I'll also probably be posting in other sections with updates of the install listed in sig.
clearance
Originally Posted by LastBlack02SS
Looking for some help. Anyone know if I need aftermarket fans for clearance? Also, do i have clearance for a b&m tranny cooler?
send me you email address on alz28@tiscali.co.uk and I will get pics to you, the files are too big to upload to this site
Cheers Al
You sure the pulley your looking at is not the replacement tensioner pulley? And yes you are suppose to get 3 fans. 2 pushers and a larger puller. If you don't have the manual you can find it on their site.
i went with spal pusher fans and that was it, it worked just fine for me, but putting a puller on the other side is not a bad idea, and i was going to do that but i sold the (partial) kit also. I would say this, got to summit, get the THIN spal pushers, and put them in FRONT of the ac condensor/ radiator to push through. Hook them up to the regular wires for he OLD fan setup. It isnt that hard, but if you search you will find a post from JRIOS with pics on how to set up the fans. My setup was awesome, but make sure you put a FMIC on that powerdye cause if not, you will get INSANE heat temps at your manifold. After i put my FMIC on, i noticed GREAT gains!!! Good luck and i am like a powerdyne specialist so PM me if you need any help ok!
Dan
Dan
Thanks for the advice. If you look in the sig, I've got a twin ati intercooler setup going in with this kit so i hope it turns out ok numbers wise. Does anyone have part numbers for a fan setup? I just want to make sure I have the exact right part.
i used this one from summit racing equiptment
http://store.summitracing.com/defaul...5&autoview=sku
Hope this helps yah out some. I bought the whole thing just cause it came with wire to relocate your fans from the back of the radiator to the front of the ac condensor.
