Guestimated RWHP???
Guestimated RWHP???
Hello all:
My car is almost ready. All they have to do is work out the tune.
I currently have the TTi race kit (Turbonetics T76GTQ trim), built 370ci iron block with 8.5:1 compression, 60# motrons, factory ECU w/LS1Edit tuning, which is working out very well, and a TH400 w/3000 stall converter. I plan on running about 15PSI on pump and about 20+PSI on race gas.
Just wanted a guestimation from everyone. On a good tune, what do you think she'll do? This will be on a Mustang dyno.
Originally Posted by 98turbls1
I think she's going to push somewhere around mid 7xxhp @ 15psi and probably north of 900rwhp @ 20psi...Good luck and keep us posted
What kind of heads/cam?
I am gonna guess 580-600rwhp @ 15psi and 700rwhp-720rwhp @20psi all on a mustang dyno...
Whoooo Quick I think you are way undershooting it... I make 560 with an STS and a 67 Trim turbo at 9Psi. I think 98 is pretty close... I dont know what it will do at 20PSI however... 850 maybe
Originally Posted by RealQuick
Thats seems kind of high to me (especially the 20psi guess) because he has an auto/stall and its on a mustang dyno. JMO though.
KCR stage 2 heads
Thunder Racing 224/224 .561 .561 cam
Originally Posted by Mekkadon
I thought so too, maybe some RC 75# injectors?
LS1TECH Sponsor
A T76 with a Q-trim at 20+psi is going to be tough to make good power (if any more then 20 without side effects) without backpressure becoming a big issue. Also the IAT's will be screaming...make sure to pack plenty of ice in the IC.
~95 lbs/min, 2.36 PR, you will be way off the compressor map....~55% efficiency. Your compressor outlet temps will be floating ~410-420DegF.
Just something you may want to think about.
Jose
Jose
Jose
Jose
So, what PSI nets the best efficiency for my setup?
I noticed in INTMID8's post on a similar setup here (TTi race kit hot parts) he was able to make around 900RWHP (though it was an M6) but he is running a bigger A/R on the Innovative Turbo than my Turbonetics (1.15 vs my .96). Or, are there more differences between the Innovative and the Turbonetics as far as efficiency/power is concerned?
I don't know if it is possible to switch to the T76GTS with this TTi race kit. Would that help any? Guess I'll have to make a couple of phone calls. (or if mightymouse or anyone else have input, please chime in).
LS1TECH Sponsor
Jose
LS1TECH Sponsor
In order it would be...
O, P, Q, X, S, R , S4 and TM1....forgot about the last. The TM1 is new and is very hard to get right now.
BTW, the X is a touch smaller then the S. Its an R-trim wheel with a step cut into it.
Jose
Jose
