Need Help!!!!!!!
Old 12-20-2005, 06:36 PM
SgtB's Avatar
Default Need Help!!!!!!!
I know this is not for an LS1 but its for my wifes daily driver .
Its a 2000 Grand Prix GTP
Its starts runs for 2 seconds then dies...any ideas?
Old 12-20-2005, 07:14 PM
LS1TECH Sponsor
foff667's Avatar
security feature kicking in?
Old 12-20-2005, 07:28 PM
solocam's Avatar
Dealers charge about 50 to 70 bucks for a scan and auto zone scans for free.You cant get the car there so you may have to offer the local scan man 20 bucks to stop on way by and scan. Sounds like might be a fuel pump. First though check all the fuses.
Old 12-20-2005, 07:59 PM
98turbls1's Avatar
Well that's only going to work if it has a SES light...It kinda does sound like the passlock 2 system but there are other things that can make it do that...When I used to install remote starts it would do that if it wasn't getting the code from the key but that was when the key wasn't in the ignition...You may try another key if you have it...I don't know the likelyhood of the sender in the key being bad but it's worth a try
Old 12-20-2005, 08:40 PM
SgtB's Avatar
I had it towed home...can't make it to autozone...too far
I thought it was the pass lock 2 system too. I unhooked the battery for the time being and will hoot it back up later tonight and see if it does anything...if that doesn't work I will run a fuel pressure test on it tomorrow night. Hope fully resetting the PCM helps...if not I have a feeling it may be the fuel pump.
Also, I don't see any fuses for the alarm/security system....
Old 12-20-2005, 08:48 PM
98turbls1's Avatar
When you start it up try to have someone listen to the fuel tank...You'll hear a whine..Hell you can hear that just by turning it on....If it doesn't whine then it's probably the fuel pump...Those are FUN to change...Good luck brother
Old 12-20-2005, 09:20 PM
SgtB's Avatar
I hear the fuel pump...i can hear it run for a second even after it shuts off.
I've chamnged fuel pumps before they suck...well I am going to go reconnect the battery and see what happens wish me luck
Old 12-20-2005, 09:33 PM
SgtB's Avatar
Ok It started and ran for about 7-8 seconds then died....I went to start it again and it started to crank over but then it stopped so now I have it on a battery charger....
this stupid car is pissing me off!!!!
Old 12-20-2005, 09:34 PM
98turbls1's Avatar
Let us know man...Hopefully that bad dude fires up for you
Old 12-20-2005, 10:09 PM
SgtB's Avatar
well its sitting on the charger......
Do you guys know where I can find a schematic for the fuel system online???
Old 12-20-2005, 10:21 PM
98turbls1's Avatar
Hmmmm.... For a GTP?? Google!!! that's the easiest way to find anything...I don't know right off hand though...
Old 12-20-2005, 10:23 PM
98turbls1's Avatar
Hold up...Are you sure that the fuel sender didn't go out and you're just out of gas or something?? That sounds awful familar...Or maybe your fuel filter is clogged....Those would be two good places to look...You know that it's getting spark and a little fuel though...Damn, this is a tough one
Old 12-20-2005, 10:35 PM
SgtB's Avatar
uurrghhhhhh
have I ever told you how much I het my wifes car?????
I just want to
Old 12-20-2005, 10:44 PM
98turbls1's Avatar
YOu still in the Corps?? I can tell that you were in...It would be nice to use a mark 19 on that thing..hehe...I'm sure you'll get it done man
Old 12-20-2005, 11:45 PM
Okie5.3's Avatar
check the cam sensor.
Old 12-21-2005, 06:59 AM
SgtB's Avatar
It could be anything with the fuel system right now....I will use a pressure tester tonight when I get home from work and see what I come up with...I am now thinking fuel pump or regulator..
No I am out of the corps now..back in Chicago where its cold as hell am I'm trying to fix a car.
SgtB's Avatar
The cam positioning sensor???? How would that go bad?
Old 12-21-2005, 07:06 AM
horist's Avatar
really sounds like VATS to me... but fuel pump is possible (though if it's consistent in how long it runs before dying it'd make me question that)
I don't have a 2000 V6 license or else I'd disable it for ya I would try cleaning the resistor on the key real well... I'm not sure how the security system reacts on the GPs ... Is there anything weird in the DIC? (any unusual warnings?)
Oh! Something I just thought of that it may be
there's a common problem on pre 04 GPs ... something about the fuel pump resistor
http://www.ilgpc.com/forum2/index.ph...l+pump+problem
http://www.ilgpc.com/forum2/index.ph...+pump+resistor
Casper electronics actually makes a kit to do this resistor bypass thing
Old 12-21-2005, 07:09 AM
horist's Avatar
http://www.clubgp.com/newforum/tm.as...de=&s=#2729051
http://www.clubgp.com/newforum/tm.as...de=&s=#2765329
more ... this sounds like your prob
Old 12-21-2005, 07:53 AM
wrencher
wrencher's Avatar
Check the dash also when you turn the key on. The theft/security light should illuminate then go out.
If it stays on or flashes there is a VTD problem.
