Will this setup get me anywhere near 750 hp on pump gas?
I was thinking of going with a forged 346 and a D1 prochargerfor my 2000 TA. My heads would consist of AFR 225 and a GT3 cam. I already have kooks 1 3/4 stepped to 1 7/8 w/catted y-pipe and planning on going with an 90 mm Lsx intake and 90 mm NW throttle body.. I would like to reach 750 hp or higher on pump gas and even more on race gas...Just needed to know what you guys think of this setup and if it's worth the money?
Originally Posted by Tirefire
I will be forging the bottom end w/diamond pistons, girdle etc. I think Exotic Performance will due this setup in the near furture.. Hopefully they will be able to get me close to my desired hp and tq numbers.
Forged everything is in the works, what do you suggest for a crank Ferocity and do you think the heads will do? Keep in mind that I want this car to act as stock as possible. I would also like it to seem as if this is just another 500 hp procharger when people look under the hood and then BAM your mine....i.e the front mount would give it away...
408 iron block, GOOOD HEADS, small CUSTOM cam, and an F-1 will get you what you want......
only way your going to get the above. AND get the power you want is to go BIG (cubes)....... I also hope you have atleast 12k to start this project.
i've seen a 406 sbc with a fmic and a d1sc make alittle over 1000 fwhp so the head unit is easily capable of the numbers if you can match your components 700-750 rw can be reached,not easily but it can happen.
