will a tb affect my dynotune?
-sorry for the newbie question-
im planning on getting a 80mm tb real soon.do i need it before i do my dynotune?its a all bolt-on and cam car.stock heads.
should i barrow a 80mm tb tune for the tune?
A throttle body may affect the idling characteristics of your tune. Side effects may be stalling when coming to a stop or slight surging/hunting for the desired idle. You're not changing the WOT performance part of the tune...just the part the IAC sensor references.
Originally Posted by Grimes
I thihk you'll be just fine adding it later - but what intake are you bolting the 80 to?
should i barrow one for the tune maybe?
!LS1 11 Second Club
Also, why the 80mm TB? Just a ported stocker is plenty good.
i was planning on porting my stock one.i have a few different write-up/how too's,but thought the 80mm would be better.
how far are people going on stock ported?
i have a bbk 80mm lined up for 200.00.
you can have your stock ported for like 80 dollars and it is going to flow almost identical to the 80 mm because the ls6 intake is only 78mm, correct me if i am wrong here guys...
