Removing Heating&A/C from car need help
ok well as the title says i've removed all the junk from behind trhe dash which i would guess is the Vents, air ducts, Heater core, HVAC (what exactly is this) and all the A/C components. What i need to know is what are the three plug ins on the back of the intake manifold. The Map Sensor the brake booster and whats the other small one? It looked like it was connected to the a/c unit or soemthing of that nature. Is it needed? should it be plugged what do i do w/ it? thanks in advance
Adam
Adam
thanks
anybody else, pics etc what do i do? The little line looks liekt eh ones that were on top of the HVAC system and everything there were like 4 of them? but only one plugged into the intake manifold
thanks
can i get other feedback as well, or will that pretty much cover it? It's not needed if i pull the cooling/heating setups correct? Just plug it up and I'm good to go?
anything else in that area that needs special attention upon removal?
Oh Snap, lol Yeah still doing the tear down ordered the cam get ready man should have it in the next week, valve springs same, then i just need pushrods, lifters the timing chain oil pump, , and if im lucky the underdrive pulley. Then theres just a couple gaskets then the PCV hose you got for me and that damned power steering pulley! lol
Javi, you have a dif. intake manifold what did you do for all the sensors in the back do you know what ehtey all are?
Originally Posted by 02WS6Bird
This all appears to be connected and i would liekt o know if its safe to get rid of it
